Configuring UART in STM32F429I DISC1 board
   I recently started learning ARM programming and currently taking a course on Udemy.
It covers GPIO, SPI, I2C and and UART register level programming. So far I have only been able to make GPIO code work. For communication protocols like SPI & I2c it uses two development board. The course is done on STM32F407 DISCovery board.
I am using a different board than the one used in the course, STM32F429ZI DISC1
Both controller have same Reference manual. Only difference i could find is pins, and RCC control register. So code developed for STM32F407 should work in STM32F429ZI controller with little difference. But I couldn't make SPI code work in my board. So i decided to write UART code , so that I can use it on SPI code for debugging. But UART code is also not working.
Google drive contains all the documents and code that I developed for SPI and UART. Once I could figure out why UART is not working I think I could use that in SPI code to figure out the issue.
I also tried following code that I found online, it also use STM32F4xx series controller but not the same as mine. It is not working too.
/* p4_5.c C library Console I/O using USART2 at 9600 Baud
 * This program demonstrates the use of C library console I/O.
 * The functions fputc() and fgetc() are implemented using
 * USART2_write() and USART2_read() for character I/O.
 * In the fgetc(), the received character is echoed and if a '\r'
 * is received, a pair of '\r', '\n' is echoed.
 * In fputc() and fgetc(), the file descripter is not checked. All
 * file I/O's are directed to the console.
 * By default, the clock is running at 16 MHz.
 * The USART is configured for 9600 Baud.
 * PA2 - USART2 TX (AF7)
 * PA3 - USART2 RX (AF7)
 * Use Tera Term on the host PC to send keystrokes and observe the display
 * of the characters echoed.
 * This program was tested with Keil uVision v5.24a with DFP v2.11.0
#include "stm32F4xx.h"
#include <stdio.h>
void USART2_init(void);
void delayMs(int);
void USART2_write(int c);
int USART2_read(void);
int main(void) {
    int n;
    char str[80];
    USART2_init();
	  USART2_write('c');
    while (1) {
/* initialize USART2 to transmit at 9600 Baud */
void USART2_init (void) {
    RCC->AHB1ENR |= 1;          /* Enable GPIOA clock */
    RCC->APB1ENR |= 0x20000;    /* Enable USART2 clock */
    /* Configure PA2, PA3 for USART2 TX, RX */
    GPIOA->AFR[0] &= ~0xFF00;
    GPIOA->AFR[0] |=  0x7700;   /* alt7 for USART2 */
    GPIOA->MODER  &= ~0x00F0;
    GPIOA->MODER  |=  0x00A0;   /* enable alt. function for PA2, PA3 */
    USART2->BRR = 0x0683;       /* 9600 baud @ 16 MHz */
    USART2->CR1 = 0x000C;       /* enable Tx, Rx, 8-bit data */
    USART2->CR2 = 0x0000;       /* 1 stop bit */
    USART2->CR3 = 0x0000;       /* no flow control */
    USART2->CR1 |= 0x2000;      /* enable USART2 */
/* Write a character to USART2 */
void USART2_write (int ch) {
    while (!(USART2->SR & 0x0080)) {}   // wait until Tx buffer empty
    USART2->DR = (ch & 0xFF);
    //return ch;
/* Read a character from USART2 */
int USART2_read(void) {
    while (!(USART2->SR & 0x0020)) {}   // wait until char arrives
    return USART2->DR;
I am using this USB TTL to connect b/m board and PC and mobaXterm as terminal
these are the terminal settings. I use
 IDE: Keil uVision 5.27
I am really stuck
