Is Overwriting Ex-READ allowed when Ex-Write Response is pending?
The sequence of operations in the current scenario is as follows:
1. Master issues an exclusive read
2. Master receives EXOKAY response for this exclusive read
3. Master issues an exclusive write with same id and control parameters
4. Master has not yet received the response for above exclusive write.
Now, is the master allowed to issue another exclusive read with same ARID? Or does the master have to wait for the write response to issue exclusive read with same ID?
Also, from the slave’s perspective, if it receives the second exclusive read before issuing write response for the exclusive write, how should the slave treat it?
1. Should it accept the second read request and overwrite the exclusive monitors? In this case, whenever the slave issues response for the above write, it will issue OKAY response.
2. Should the slave not accept the second read request and issue OKAY response for this read and continue with issuing EXOKAY response for the write (provided the memory is not written by any other access)?
