GIC 3.0's SGI interrupt latency seems much bigger than GIC 2.0
I tested SGI interrupt latency, it seems that GIC3.0's SGI interrupt latency are much bigger than GIC2.0.
How to test:
GIC3.0:
1. read timestamp(t01)
2. core0 write  ICC_SGI0R_EL1 to trigger core1, read timestamp(t02)
3. isr in core1, read timestamp(t03)
GIC2.0:
1. read timestamp(t11)
2. core0 write GICD_SGIR to trigger core1, read timestamp(t12)
3. isr in core1, read timestamp(t13)
Result is (had think about the time of reading timestamp):
1. (t02 - t01)  nearly 3 times bigger than (t12 - t11)  which means system register cost more time than access to memory mapped memory.
2. (t03 - t02) nearly 2 times bigger than (t13 - t12) which means interrupt latency of GIC3.0 are much bigger than GIC 2.0
Is this normal? Any help will be appreciated! Thanks!
BR,
Peng
