AHB Lite Multiple burst without idle transfer
Hi All,
               Consider the following burst transfers.
1. INCR4 (WR) IDLE INCR4(RD)
2. INCR4 (WR) INCR4(RD)
3. INCR4 (WR - WR1 ,WR2, IDLE, WR3 ,WR4 )   INCR4(RD)
             All the above transactions are valid transfer or not .
Can we trigger multiple burst without giving idle transfer ?
Can we trigger IDLE transfer within the burst .
Thanks & Regards
Muthuvenkatesh
  • Hi Muthuvenkatesh
    I'm not too sure what your sequences are showing, so I'll explain what I think the sequences are, and then if they would be legal.
    1 - INCR4 (WR) IDLE INCR4(RD)
    This is HTRANS signalling NONSEQ-SEQ-SEQ-SEQ-IDLE-NONSEQ-SEQ-SEQ-SEQ, so 2 complete 4-beat bursts, with an IDLE in between.
    This would be legal (assuming HREADY is high for each transfer to keep things simple).
    2 - INCR4 (WR) INCR4(RD)
    The same sequence as above, but without the IDLE in between the 2 4-beat bursts.
    Again perfectly legal, there is no requirement to have an IDLE in between bursts.
    3 - INCR4 (WR - WR1 ,WR2, IDLE, WR3 ,WR4 )  INCR4(RD)
    This time HTRANS would be NONSEQ-SEQ-IDLE-SEQ-SEQ-NONSEQ-SEQ-SEQ-SEQ.
    This one is definitely illegal. An IDLE transfer can only happen outside of any burst, so it could not happen after the 2nd transfer of a 4-beat burst.
    If you need to stall a defined length burst you would instead use a BUSY transfer in place of the IDLE.
    I hope that was what you were describing.
