I'm wondering what the correct way to mask non secure interrupts is, on entering secure world on an ARMv8-M processor, with Main and Security extensions. The scenario I have is as follows:
The SOC has 1 M33 core. I have a non secure OS that has an RTOS and schedules threads etc.(RTX RTOS2). The core has 2 Systick timers implemented, 1 for each world. The RTOS configures the non secure timer with priority 0. The secure world sets up AIRCR.PRIS=1 during boot, which means, the NS view of the timer priority is 0, but the view from secure world(SHPR*_NS) is 0x80.
The secure side exposes a bunch of secure function calls, that are called from RTX/NS threads. Some of these functions are not thread safe, so I would like to disable interrupts during execution of these functions, so that the NS timer does not fire and secure world execution is not preempted.
On ARMv8-A, on entry into secure world through SMC, the processor automatically masks interrupts. However, the SG instruction does no such masking. My questions are as follows:
1) Is there a way to make the core automatically boost the current execution priority to mask interrupts on entry into the secure world ? Or is there some banked register, whose state is retained and has the effect of masking interrupts only when executing in a particular world ?
2) I tried setting PRIMASK to 1 and it works, but it seems like I have to set PRIMASK back to 0 before leaving secure world. If not the execution priority does not drop back and the non secure interrupts never fire again. Is this expected behavior? I thought that the PRIMASK would only affect the secure world, since the PRIMASK register is banked between security states.
3) I tried writing the BASEPRI register but the write was ignored, even though the core was in privileged/handler mode. How would I use the BASEPRI register to address my scenario ?
It seems like the best approach to solve my issue would be to implement secure world mutex's that set PRIMASK to 1 on mutex acquire and PRIMASK to 0 on mutex release. Is this the correct approach ? it seems like using BASEPRI to mask non secure interrupts only would be a better approach, in case I have secure interrupts that need to be handled.
Hi Sanjeev,
Just read through you message again and realized you might have misunderstood one thing:
The interrupt priority level space is "shared" between Secure and Non-secure world:
- Secure masking registers can affect both Secure and Non-secure interrupts. Effective masking level in Non-secure side is adjusted based on value of AIRCR.PRIS.
- Non-secure masking registers can also affect Secure and Non-secure interrupts. Effective masking level in Secure side is adjusted based on value of AIRCR.PRIS.
Hence setting PRIS to 1 and BASEPRI_S to 0x80 means blocking Non-Secure interrupts of priority level 0x00 to 0xFF.
If BASEPRI_NS is set to 0x80, and if PRIS is set to 1, it blocks Secure interrupts with priority levels 0xC0 to 0xFF.
So your observation is normal.The banking of these masking registers is needed as Non-secure ISRs can change the values of the Non-secure masking registers, so if a Secure process need to have the priority level masking protected, it cannot rely on the Non-secure BASEPRI/PRIMASK to handle the masking.
Regarding support channel, assumed that you work for a semiconductor company that licensed Cortex-M33, then Arm support is the best way to handle your enquiries. Arm community page is not a replacement for support.
regards,
Joseph
Hi Joseph,
Thanks for the response. That explanation pretty much explains everything. The ARM manuals maybe improved with such explanations.
Yes, since the settings of BASEPRI/PRIMASK can manipulate the priority level masking in either world, the best way of handling seems to be manipulating the settings of BASEPRI/PRIMASK at the entry and exit points of secure code.
Ex: BASEPRI_S = 0x80 at entry and BASEPRI_S = 0x00 at the exit of the secure code.
regards,sanjeev.
