Instruction Fetches from Peripheral Memory Space
Is it possible to use the MPU to configure the Peripheral Memory Space as Execute?
It looks possible via the MPU_RBAR.XN bit.
If this is the case, is it fair to say that TrustZone aware select gates need to monitor HPROT[0] or PPROT[2] and block the transaction if it is an instruction fetch?
  • Hi
    could you possibly elaborate on what you are trying to protect from?
    is the scenario that someone configure peripheral space as executable then jumps to that code to bypass secure/non secure?
    thanks
  • Hi
    thanks
