Have existing setup for CortexM3 to generate bootcode from C tetscases.
Able to use same setup to generate bootcode for Cortex-M4 with minimum changes.
But seeing issue while using same setup for Cortex-R4.
Added "--apcs /interwork" and changes cpu name " --cpu=Cortex-R4" in armcc command .
getting below error.
Error: L6242E: Cannot link object common_function.o as its attributes are incompatible with the image attributes.
... arm-isa clashes with m-profile.
Error: L6242E: Cannot link object default_handler.o as its attributes are incompatible with the image attributes.
Error: L6242E: Cannot link object vector_table.o as its attributes are incompatible with the image attributes.
Error: L6242E: Cannot link object qspi.o as its attributes are incompatible with the image attributes.
Let me know if you have any idea.
Cortex-M3 and Cortex-R4 have completely different architecture and
Cortex-M3 procedure cannot apply to the Cortex-R4.
Cortex-M3 follows ARMv7-M architecture.
Cortex-R4 follows ARMv7-R architecture.
ARMv7-R architecture is very similar to ARMv7-A architecture which is implemented by 32 bit Cortex-A cores.
Best regards,
Yasuhiko Koumoto.
Hi Yasuhiko,
Thanks for response.
I do understand that M3 and R4 have different architecture.
But from bootcode generation point of view, once we modify vector table file and scatter file as per R4 (ARMv7-R) architecture wouldn't it be possible to reuse M3 arm compiler/linker commands(cpu=Cortex-R4)??
regards,
raj
Hi raj,
I wonder how you modified the vector table.
The vector table structure of Cotex-R4 is not the same as one of Cortex-M3.
For Cortex-R4, the vector table includes instructions.
For Cortex-M3, the vector table includes handler addresses.
The vectors are not compatible with each other.
I cannot believe that Cortex-R4 boot codes can be generated from Cortex-M3 boot codes.
HI Yasuhiko,
I got your point.. I was trying create vector file(with handler address) for R4 also.
As you mentioned above, that is NOT Correct.
Thanks for your response.
Raj
Hi All
IF anyone in forum have Cortex-R4 related bootcode setup example(C based) or document that explain bootcode setup .. Please share.
View all questions in Cortex-R / R-Profile forum
