Bootcode geneartion from C testcase for Cortex_R4
Have existing setup for CortexM3 to generate bootcode from C tetscases.
Able to use same setup  to generate bootcode for Cortex-M4 with minimum changes.
But seeing issue while using same setup for Cortex-R4.
Added "--apcs /interwork"  and changes cpu name " --cpu=Cortex-R4" in armcc command .
getting below error.
Error: L6242E: Cannot link object common_function.o as its attributes are incompatible with the image attributes.
   ... arm-isa clashes with m-profile.
Error: L6242E: Cannot link object default_handler.o as its attributes are incompatible with the image attributes.
Error: L6242E: Cannot link object vector_table.o as its attributes are incompatible with the image attributes.
Error: L6242E: Cannot link object qspi.o as its attributes are incompatible with the image attributes.
Let me know if you have any idea.
