Memory Alignment for VSTM/VLDM Instructions on Cortex R52
Hello All,
Assumptions :
1.SIMD operations are enabled.
2.Q0 - Q7 registers contain value zero.
3.r0 contains the array pointer which will zero out the memory.
I am using vstm instruction to zero out memory out faster.
VSTM         r0!, {q0 - q7}
I wanted to know what type of memory alignment is required before doing this operation? Will it give it an alignment fault if used with device type memory?
Thanks,
okale
