Longer pipelines on Cortex R's vs real-time & performance
On Cortex M's , you have 3 stage pipelines, while Cortex R's starting from R4 up you have 8 stage, and R7 even 11.
I don't understand, isn't worse for real-time interrupt response to have longer pipelines? I did read that Cortex-R can interrupt long stores/loads, and jump straight to the vector address & the irq number passed, that is great, but doesn't the pipeline get flushed every hw interrupt or exception/fault, and needs to be re-filled with instructions? So more cycles spent.?  And, it's not that the pipeline get saved for return from interrupts..?
There are no posts to show. This could be because there are no posts in this forum or due to a filter.
