There are two questions about coherence between R82 and others as:
R82 only with a ACE5-LITE interface
Hi summer123
Are you still looking for help with this?
hi,Oliver
yes, could you help to reply on this?
Hi summer123, fixxxer and Bastian Schick are top answerers for this forum. Can either of you help with this question?
In the public datasheet of Cortex-R82
https://developer.arm.com/-/media/Arm%20Developer%20Community/PDF/Arm_Cortex-R82_Processor_Datasheet.pdf?revision=702dda08-8ef9-4064-a461-293747c73a82&la=en&hash=9167E767B0899F607DB500F09197AA726FE180E4
Cortex-R82 can support AXI or CHI-E Main Master port, if CHI-E is used, then with coherent interconnect, it supports hardware coherency for multiple Cortex-R82 clusters or Cortex-A clusters.
If you were talking about the cache coherency within cores in one Cortex-R82 cluster, then L2 memory system in the cluster is able to maintain cache coherency between them.
If using Cortex-R82 ACP port, an ACE5-Lite 128-bit shared slave main Accelerator Coherency Port (ACP) for external access to MM address ranges. ACP enables I/O coherency for external agents with the per-core L1 data cache and shared L2 cache.
View all questions in Cortex-R / R-Profile forum
