What does "low interrupt latency" means
Hi All,
In R4 trm, there are some words about low interrupt latency. I have a question about it.
"   Low interrupt latency
On receipt of an interrupt, the processor abandons any pending restartable memory operations.
Restartable memory operations are the multiword transfer instructions LDM, LDRD, STRD, STM, PUSH,
and POP that can access Normal memory.
To minimize the interrupt latency, ARM recommends that you do not perform:
• multiple accesses to areas of memory marked as Device or Strongly-ordered
• SWP operations to slow areas of memory."
My question is that:
Suppose I use the LDM instruction and this causes a cache miss, and this cache miss triggers line fill which take forever. This hangs my cpu. So my cpu cannot respond  any more. In this case, will IRQ/FIQ trigger the cpu to abandon this LDM? If yes, what kind of special configuration I need. Thanks.
Best,
Patrick
