Hi All,
In R4 trm, there are some words about low interrupt latency. I have a question about it.
" Low interrupt latency
On receipt of an interrupt, the processor abandons any pending restartable memory operations.
Restartable memory operations are the multiword transfer instructions LDM, LDRD, STRD, STM, PUSH,
and POP that can access Normal memory.
To minimize the interrupt latency, ARM recommends that you do not perform:
• multiple accesses to areas of memory marked as Device or Strongly-ordered
• SWP operations to slow areas of memory."
My question is that:
Suppose I use the LDM instruction and this causes a cache miss, and this cache miss triggers line fill which take forever. This hangs my cpu. So my cpu cannot respond any more. In this case, will IRQ/FIQ trigger the cpu to abandon this LDM? If yes, what kind of special configuration I need. Thanks.
Best,
Patrick
Hi Patrick,
the situation you describe is exactly where the Low latency interrupt mode is designed to help. It's described in more detail in the TRM halfway down this page: ARM Information Center and enabled by default. On returning from the interrupt, the LDM will be restarted. No special configuration should be needed.
regards,
Jon
Hi Jon,
Thanks for your reply. I can't agree with you more.
But based on our system, when the R4 hangs because LDM, my interrupt is still not served. This LDM doesn't get any data back since the data request shows up on the AXI. AXI read data response channel never gives any valid data back. Will this block something like LSU/PFU to get the ISR code from ITCM?
Thanks,
Although it's unlikely, can you check that the Low Latency bit is still set in the system control register?
The other possibility is that the address you are accessing has been marked by the MPU as Device or Strongly ordered memory. The memory attributes are described in more detail in the TRM here:ARM Information Center
This application note may also be helpful:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dai0296a/index.html
Please note that even if the MPU is disabled, although no access checks are performed, there is still a default memory map which has regions of strongly ordered and device regions - see here for details:
Thanks for your reply. In the past days I did some arm simulation to catch the problem. I can make ARM-R4 serve FIQ when LDM is on-going now. In my ISR, I try to use STR instruction, but i cannot see any transaction on the AXI-Main interface. I am wondering whether LSU is stopped because of the previously un-responded LDM.
when you say you did some simulation, are you simulating RTL, or is this on a model? What sort of memory is the store going to? (ie just checking it's not on a TCM interface). Even if it's to normal memory, it could be ending up in the cache depending on whether you have write-through or write-back mode configured. Just trying to make sure I've got a full picture of your system.
View all questions in Cortex-R / R-Profile forum
