I am working with TI's TMS570LS3137 (ARM Cortex R4F).
A certain part of my code consistently causes a prefetch abort (I say part because the exact location seems to vary slightly).
To try and identify the cause I set a breakpoint at the prefetch abort handler (0x0000000C) and looked at the following registers:
Here is how I disabled parity/ECC check:
// Disable CPU parity/ECC check asm(" PUSH {r1}"); asm(" MRC p15, #0, r1, c1, c0, #1"); // Read ACTLR asm(" BIC r1, r1, #0x0E000000"); // Clear ATCMPCEN, B0TCMPCEN, B1TCMPCEN asm(" MCR p15, #0, r1, c1, c0, #1"); // Write ACTLR asm(" POP {r1}");
These observations leave me with two questions:
Thank you in advance
View all questions in Cortex-R / R-Profile forum
