I am using ARM Cortex R4F core and i want to know about the J bit in the CPSR/SPSR Field.
What is the purpose if this bit?
As per the Document, we can read the J bit value as 0. Is this condition is always true?
And if i want to enable this bit, How can i do that?
Can anyone please explain me this?
Regards,
Shivam Kakad
Seems clear enough:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0363e/ch02s06s01.html
It's a bit that reads as zero.
Putting "Cortex R4F J bit CPSR/SPSR" into google also gives:
https://heyrick.eu/armwiki/The_Status_register
Which suggest that it would only be '1' if the Jazelle instruction set were present
Further googling:
https://en.wikipedia.org/wiki/Jazelle#CPSR:_Mode_indication
How to write the J bit to 1 then?
As msr cannot be used to set it as 1.
shivam30 said:How to write the J bit to 1 then?
Why would you want to do that?
As noted above, it tells you about what's built into the chip - so writing to it is meaningless!
View all questions in Cortex-R / R-Profile forum
