I am using Xilinx MpSoc Ultrascale+ ZCU102.
I want to generate an interrupt when dividing by zero.I read the Cortex-R5 technical reference manual (infocenter.arm.com/.../index.jspThe system control register C1 has the DZ bit which control the generation of Undefined Instruction exception. My SW is running as a standalone on R5-0.The file xreg_cortexr5.h consists the XREG_CP15_CONTROL (the C1 Register Defines) but the DZ bit is not exist there. When I tried to change this bit by myself (using inline assembler code) according to the ARM Cortex-R5 details mentioned above and handle this with my own function, I got a SW interrupt in every cycle of my application. Why the DZ bit is not appear in xreg_cortexr5.h?Why changing its value cause a SW interrupt?
Is there a different way to generate the divide by zero interrupt?
Thanks!
Hi Andy,
Thanks for that!
Any help with my question?
