i am using ARM Cortex R4F core and want to initialize SPSR register with zero. i tried using below assembly command:
mov r1, #0x0000
msr spsr_cxsf, r1
MRS r2, spsr
MRS
To validate above commands, during run time i have written 0xFFFFFFFF to r1 so that i can write 0xFFFFFFFF to SPSR register. But when i read back SPSR register which is third instruction above r2 has 0xFE0FFFFF
J and DNM fields of SPSR register are read a zero. can you please help me to understand this behaviour?
Thanks,
Kalyan
Check the manual, certain registers have bits which RAZ (read as zero).
