I'm designing a MCU platform that is using ROM and RAM.
My boot up scenario is as follows.
First, ROM F/W is executed after power up(ROM F/W is excecuted only 1 time).
And then, core waits for until program counter jump flag goes high at the end of ROM F/W
When program counter jump flag goes high, core PC jumps to the RAM region, and executes RAM F/W.
To operate above scenario, I'm trying to implement F/W code.
// sram_main(); while(ready_SRAM == 1); __asm { B 0x00002000; }
I thought I could insert inline assembly in the code lik above, but I got an error like below.
Error: #1113: Inline assembler not permitted when generating Thumb code
I found the resolution in the ARM information Center as below. But it doesn't work for my case.
If you want to include inline assembly in code to be compiled for Thumb, enclose the functions containing inline assembler code between #pragma arm and #pragma thumb statements (see Pragmas controlling code generation). For example:
#pragma arm
#pragma thumb
#pragma arm int add(int i, int j) { int res; __asm { ADD res, i, j // add here } return res; } #pragma thumb//Does anyone know to insert inline assembly in code to be compiled for Thumb code? or how can I make F/W which core program counter can jump from ROM to RAM?Thank you.
Why not simply do this:
void (*func)(void) = (void (*)(void))0x2001;
func();
Thank you for your reply. I'll try.
