Forced Hardfault (INVPC) Exception Error
Using ARM coretx-M chip set
Getting random  INVPC hard fault exception error, while running iperf tool for measuring n/w throughput.
Hard fault reg: 0x40000000
xPSR: 0x01000000
PRIMASK: 0x00000001
CONTROL: 0x00000000
Please help to find the possible root cause.
  • Assumed that you are using Cortex-M3/M4/M7, there are a number of possible reasons:
    - corruption of EXC_RETURN during interrupt handling. This could be caused by stack corruption, or incorrectly implemented context switching code.
    - corruption of stacked PSR during interrupt handling. This can lead to incorrect IPSR or ICI/IT which can both result in INVPC,
    - Incorrect use of VECTCLRACTIVE bit / SCB->SHCSR that cleared the active status of an interrupt which is still running.
    regards,
    Joseph
    regards,
    Joseph
