MPU is not triggering MemFault or HardFault
MPU is not triggering MemManage fault. I want to protect a memory region of 64 bytes starting from 0x20000000. I've configured the MPU registers accordingly, but when I write in a protected memory location, MPU does not trigger fault.
Here's a code that demonstrate the problem,
#define MPU_CTRL  (*((volatile unsigned long*) 0xE000ED94))
#define MPU_RNR   (*((volatile unsigned long*) 0xE000ED98))
#define MPU_RBAR (*((volatile unsigned long*) 0xE000ED9C))
#define MPU_RASR (*((volatile unsigned long*) 0xE000EDA0))
#define SCB_SHCSR (*((volatile unsigned long*) 0xE000ED24))        //System handler control and state register
void Registers_Init(void)
    //MPU Configuring
    MPU_RNR = 0x00000000;                // region in 0.
    MPU_RBAR = 0x20000000;              // base address is 0x20000000.
    MPU_RASR = 0x1608FF0B;             // 64 bytes, ro/ro, b=s=c=0
    SCB_SHCSR |= 0x00010000;           // enable MemManage Fault
    MPU_CTRL = 0x00000005;              // enable memory protection unit,guaranteeing default priviliged access
void MemManage_Handler(void)
    __asm(
        "MOV R4, 0x77777777\n\t"
        "MOV R5, 0x77777777\n\t"
void HardFault_Handler(void)
    __asm(
        "MOV R6, 0x77777777\n\t"
        "MOV R7, 0x77777777\n\t"
int main(void)
    Registers_Init();
    while(1)
        __asm(
            "LDR R0, =0x20000000\n\t"
            "MOV R1, 0x77777777\n\t"
            "STR R1, [R5,#0]"
    return (1);
void SystemInit(void)
So, in main function I am writing in a memory location protected by mpu. But instead of generating MemManage fault or even HardFault, it writes successfully.
Why is that?
