What happens when offset value becomes 30 in case of load/store operation
Hello to all,
I was looking at different offset values for both load and store operations. Since due to little endian arrangement, the memory looks something like this to processor:
Byte[0x23],Byte[0x22],Byte[0x21],Byte[0x20]
Byte[0x1F],Byte[0x1E],Byte[0x1D],Byte[0x1C]
Byte[0x7],Byte[0x6],Byte[0x5],Byte[0x4]
Byte[0x3],Byte[0x2],Byte[0x1],Byte[0x0]
Since the different value consumes different cycles:
Offset(0xn) (n ∈ 0,4,8,...) = 1 cycles
Offset(0xn) (n ∈ 1,5,9,...) = 3 cycles
Offset(0xn) (n ∈ 2,6,A,...) = 2 cycles
Offset(0xn) (n ∈ 3,7,B,...) = 3 cycles
Therefore for offset 30 => 0x1E should consumed 2 cycles since it belongs to the category of 2 offset. Rather, it has consumed 1 cycles and thereafter on all the next coming offset value, offset 30 becomes reference. I mean, for offset 32 => 0x20 (ideally it should consumes only 1 clock-cycles, but in reality it is consuming 2 clock cycles) and so on.
Does anybody know the reason behind this??
Kindly help me out with that.
Thanking you,
Regards,
Himanshu
