How to use compiled Hex file from Keil on windows to the design_start?
Thanks for your supporting in advance, As I know M0 or M3's design start kit have some example which is firmware such as Hello.
If I compiled that Hello firmware in the window, then can I use directly into the design start kit? or should I need to have a something process to use compiled firmware hex file on window into the design start kit on linux?
And I want to know what is fairly the common way to develop the firmware between window and linux?
