Cortex M4: Atomic and Cache
Hello all,
       Recently I came across this issue for the cortex M4 core.
       We are running a freertos application which loads and stores the value of a variable.
       For this we are using the atomic functions like atomic_load, atomic_store and atomic_compare_exchange_strong.
       Issue :
       *   The issue is when in the cacheable region, atomic_load and  atomic_store works fine.But any atomic read-modify-write operation
       (atomic_compare_exchange_strong, fetch_add, etc.) doesn't operate as expected.
       *  The  atomic_load and  atomic_store is able to load and store values in the cache region while atomic_compare_exchange_strong is
       working only on memory not on cache.
       * Are there any restrictions for any atomic read-modify-write operations ?
       * Is there some configuration that needs to be done in order to for caching to work with atomics? It seems as if Load-link and Store-Conditionals functions are going around the cache to either DDR or OCRAM.
Thanks,
Shrikant
