CM4: Write buffer with enabled MPU
I have a question regarding Memory protection unit on Cortex M4 (STM32F3 MCU). This is pretty simple single core MCU without caches. I implemented MPU based on instructions in Definitive guide to the ARM Cortex-M4. It is stated there that the bufferable attribute of the memory, if it is defined by the MPU and the MPU is enabled, has higher priority than the default condition.
So, I defined a peripheral region (addresses from 0x40000000 - 0x5FFFFFFF) as a separate MPU region (full access, execute never) with bufferable attribute set. Is there any chance to see or to distinguish the behaviour if I set bufferable attribute or not?
The same for internal SRAM. First of all, is SRAM bufferable at all? And how to see difference if I set this attribute for SRAM or not?
There is also a prefetch block which is used for instruction fetches over the ICode bus. Is this somehow connected with cacheable attribute. Do I have to define a cacheable attribute for Flash, if it is coverd by the MPU?
Thank you in advance,
Matic
