Cortex M4 Conditional Branch - Pipeline
Hello all!
So I'm working on a development with a Cortex M4 and there is something i don't understand, I was hoping someone could help clarify this:
This is the code I' using
(Assume R3 content is 1, R6 R8 the address needed to set PIN1, and R11 R9 the address needed to set PIN2)
asm ( "CMP R3,#0 \n\t");
asm ( "BNE NCycles_CapDelay2 \n\t");
/*asm ( "NOP \n\t"
            "NOP \n\t"
            "NOP \n\t");*/<-----------------------------------
asm ( "STR R6,[R8] \n\t"); //PIN1 SET
asm ( "STR R11, [R9] \n\t" //PIN2 SET
asm ( "B SOMEWHERE_ELSE\n\t");
asm ("NCycles_CapDelay2: \n\t");
/*asm ( "NOP \n\t"
            "NOP \n\t"
asm ("LOOP_NCycles_CapDelay2: \n\t");
asm ( "SUBS R3, #1 \n\t");
asm ( "bne LOOP_NCycles_CapDelay2 \n\t");
The thing is: If i leave the NOPs commented, the time between PIN1 set and PIN2 set is 7 cycles, and if i UNcomment those NOPs, the time is 1 Cycle (measured externally with OSC)
And when R3=0, the time difference is 0 Cycles (UNcommented NOPs) to 1 Cycle (commented NOPs)
Any ideas with what is happening with the pipeline and conditional Branches here?
Thanks for any ideas.
BR
