Cortex M4 L1 data cache policy
I have some confusions about the difference between write back + write allocate and write back + write no allocate on Cortex CM4.
As my original understanding:
  • For write back with write allocate:
    • If write-address isn't cache hinted yet, cache line will be allocated and filled, data is written to cache line but real physical device
    • If write-address is hinted yet, data will be written to cache line but real physical device.
  • For write back with write no allocate
    • If write-address isn't  hinted, no cache line will be allocated, data will be pushed to device directly.
    • If write-address is hinted, data will be written to cache line but device
But i see such description in Cortex-A7 TRM:
"All Inner Write-Back memory is treated as Write-Back Write-Allocate ignoring any cache
allocate hint, though this can dynamically switch to no write-allocate, if more than three
full cache lines are written in succession."
Seems write back with write allocate is almost same with write back with write no allocate on CA7? I didn't see similar description on CM4, CA9 and CA53 TRM. What's the behavior for write back with write allocate/non allocate on CA9, CA53 and CM4?
  • For Cortex-M4, there is no internal cache and cache hint instructions are executed as NOPs (no operations). Therefore this is no such description in Cortex-M4 TRM. However, it does export cacheable attribute to the bus (AHB Lite + additional memory attribute sideband). How the cache attributes are handled is up to the system level cache design.
    Sorry that I don't have the answers for Cortex-A9 and A53.
