CMSIS DSP - Realtime FIR Filter, Sample by Sample Issue
I'm trying to implement a realtime lowpass FIR filter using the CMSIS library.
I'm essentially following this example:
The only difference is that instead of running the filter on a block of samples, I want to run the filter sample by sample. I want to feed one sample from the ADC into the fir function and output the resulting sample to the the DAC. So I decided to use a blocksize of 1.
Here's my relevant code. I have other code for the ADC and DAC which I know works. However, if you want the full code, I can post that as well.
#include "main.h"
#include "stm32f4xx_hal.h"
#include "arm_math.h"
#define BLOCK_SIZE 1
#define NUM_TAPS   29
uint32_t ADC_Buffer[2];
uint32_t DAC_Buffer;
float32_t signal_in = 0;
float32_t signal_out = 0;
float32_t totalval = 0;
uint32_t blockSize = BLOCK_SIZE;
arm_fir_instance_f32 S;
static float32_t firStateF32[BLOCK_SIZE + NUM_TAPS - 1];
static float32_t firCoeffs[NUM_TAPS] = {
        -0.0018225230f, -0.0015879294f, +0.0000000000f, +0.0036977508f, +0.0080754303f,
        +0.0085302217f, -0.0000000000f, -0.0173976984f, -0.0341458607f, -0.0333591565f,
        +0.0000000000f, +0.0676308395f, +0.1522061835f, +0.2229246956f, +0.2504960933f,
        +0.2229246956f, +0.1522061835f, +0.0676308395f, +0.0000000000f, -0.0333591565f,
        -0.0341458607f, -0.0173976984f, -0.0000000000f, +0.0085302217f, +0.0080754303f,
        +0.0036977508f, +0.0000000000f, -0.0015879294f, -0.0018225230f
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_TIM2_Init();
  MX_ADC1_Init();
  MX_ADC2_Init();
  MX_DAC_Init();
  if(HAL_ADC_Start(&hadc2) != HAL_OK)
    return 0;
  HAL_ADCEx_MultiModeStart_DMA(&hadc1, ADC_Buffer, 2);
  HAL_DAC_Start_DMA(&hdac, DAC_CHANNEL_1, &DAC_Buffer, 1, DAC_ALIGN_12B_R);
  HAL_ADC_Start_IT(&hadc1);
  HAL_TIM_Base_Start(&htim2);
  arm_fir_init_f32(&S, NUM_TAPS, (float32_t *)&firCoeffs[0], (float32_t *)&firStateF32[0], blockSize);
  while (1)
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
  if(hadc->Instance == ADC1)
    ADC_Buffer[0] = ADC_Buffer[0] & 0x00000FFF;
    signal_in = (float32_t)ADC_Buffer[0]*3/4096;
    signal_in = signal_in - 0.5f;
    arm_fir_f32(&S, &signal_in, &signal_out, blockSize);
    signal_out = signal_out + 0.5f;
    totalval = signal_out*4096/3;
    DAC_Buffer = (uint32_t) totalval; //signal_out;
The problem is that I always get the same signal_out no matter how signal_in changes. After stepping through the arm_fir_f32() function, signal_out is always -1.9764*10^-22.
Another strange thing is that all the firStateF32 values are 0. They never change.
The only thing I'm essentially doing differently from their example is using a blocksize of 1.
Any ideas where I'm going wrong?
