Hi to you all,I've a firmware running on a NXP LPCLink2 (LPC4370: 204 Mhz Cortex M4 MCU) board which basically does this:
My problem is that my code is too slow, and every now and then and overwrite occurs.
Using the DMA I'm saving the ADC data, which I get in Twos complement format (Offset binary is also available), in a uint32_t buffer and try to prepare them for the CMSIS DSP function by converting the buffer into float32_t: here's where the overwrite occurs. It's worth saying that I'm currently using Floating point Software, not hardware.
The CMSIS library also accepts fractional formats like q31_t, q15_t and so on, and since I don't strictly need floating point maths I could even use these formats if that could save me precious time.It feels like I'm missing something important about this step, that's no surprise since this is my first project on a complex MCU, any help/hint/advise would be highly appreciated and would help me in my thesis.
I'll leave here the link for the (more datailed) question I asked in the NXP forums, just in case: LPC4370: ADCHS, GPDMA and CMSIS DSP | NXP Community .
Thanks in advance!
This is about the code that you posted in NXP Community.
Your code temporarily converts the negative ADC values to positive (by "manual" two's complementing) and eventually you convert back to negative by multiplying by -1. I suggest that you explore alternate, which can be more efficient, ways of converting from 12-bit signed integer to floating-point format.
A possible way of converting the ADC data from 12-bit signed integer to 32-bit floating-point format is by transforming to 32-bit two's complement code then assigning the result to a floating-point variable (simply let the compiler do the rest of the work).
If the ADC data is in (12-bit) offset binary code it can be converted to 32-bit two's complement format by simply subtracting the offset (in this case the offset is 2048)
adcBuff[i] - 2048
where adcBuff[] is an array of signed 32-bit integer (int32_t). We then let the compiler convert it into floating-point format by assigning to a floating-point variable. The complete statement would be
float32Buff[i] = adcBuff[i] - 2048;
where float32Buff[] is an array of 32-bit floating-point (float32_t) data.
If the ADC data is in 12-bit two's complement code it can be converted to 32-bit two's complement format by simply sign-filling bits 12 to 31 (replicating bit 11 into bits 12 to 31). Sign-filling can be done by (logical) shifting the 12-bit ADC data 20 bit positions to the left then performing an arithmetic shift right by 20 bit positions
(adcBuff[i] << 20) >> 20
Note that there is no test for the state of bit 11. I just can't clearly recall if I previously encountered a compiler which cancels (no corresponding code generated) opposing shifts like this. Including the assignment to a floating-point variable, the complete statement would be
float32Buff[i] = (adcBuff[i] << 20) >> 20;
If the compiler produces no code for the opposite shifts, you should devise a way to circumvent that or you can resort to alternative methods. An alternate method of converting the ADC data is to transform from 12-bit two's complement to 12-bit offset binary format. The subsequent conversion to 32-bit two's complement can be done as described above for the offset binary format. Two's complement code can be converted to offset binary format by simply complementing the leftmost bit (in this case bit 11)
adcBuff[i] ^ 0X00000800
The complete conversion statement would be
float32Buff[i] = (adcBuff[i] ^ 0X00000800) - 2048;
Hi goodwin,thank you very much for all your replies. You're right, in these days I figured out that fixed math is probably the way what I'm trying to do should be done.I read your reply about the float thought, and even if I don't have the time now to try it out (I "lost", actually used, too much time and I need to move forward since all this is for my thesis!), I got the idea and for sure I'd be back on your code in the future.
I just want to give some thoughts and suggestions which might be helpful to you.
Extremely helpful. What I do need more right now is an insight from a skilled eye to point out what could be possible limitation of my design.I'm not experienced so I read some chapters on this interesting book: The Definitive Guide to ARM® Cortex®-M3 and Cortex®-M4 Processors, Third Edition: Joseph Yiu: 9780124080829: Amazon.com:…
Here there are lots of useful information about the cycles needed for each operation and I'll try to do rough calculations about how many of them my code needs.I hoped I could squeeze things to fit in that 5 cycles boundary (which I was aware of since the beginning), but, as I understand, I might be wrong.Anyway, I'm planning to follow your advice and, since I'll need to sample impulsive signals, to use the ADCHS in non-continuous mode, using the thresholds I can set and processing data when no info is being sampled. What do you think about it?
Again, thank you very much: as I said I'm developing this alone and for the first time, therefore your help is highly appreciated.
Cheers,
Andrea
Regarding the sign extension, there is a very simple way to do it : change the scale of your data !
If I understood properly, your sample buffer holds 16-bits values in which 12 lowest significant bits are the ADC output value in 2-s complement and I expect you have 4x 0-bit in front (bits 15-12).
I would symbolize this sample pair like that : sample n (0x0SA1), sample n+1 (0x0SA2)
When you use *__SIMD32(pSrc), it loads a register with both samples (0x0SA20SA1), then you just need to shift left by 4 bits to have 0xSA20SA10 which is a pair of signed 16-bits values !
I you need to keep your samples for further computations, you can write back to memory with this new scale.
This would give something like :
uint32_t SearchMinMax16_DSP(int16_t* pSrc, int32_t pSize) { uint32_t data, min, max; int16_t data16; /* max variable will hold two max : one on each 16-bits half * same thing for min */ /* Load two first samples in one 32-bit access */ data = *__SIMD32(pSrc); /* put significant bits on bits 15-4 instead of 11-0 on each halfword */ data <<= 4; /* Write back to memory to have useable 16-bits samples, increment source pointer by a pair of samples */ *__SIMD32(pSrc)++ = data; /* Initialize Min and Max to these first samples */ min = data; max = data; /* decrement sample count */ pSize-=2; /* Loop as long as there remains at least two samples */ while (pSize > 1) { /* Load next two samples in a single access */ data = *__SIMD32(pSrc); /* put significant bits on bits 15-4 instead of 11-0 on each halfword */ data <<= 4; /* Write back to memory to have useable 16-bits samples, increment source pointer by a pair of samples */ *__SIMD32(pSrc)++ = data; /* Parallel comparison of max and new samples */ (void)__SSUB16(max, data); /* Select max on each 16-bits half */ max = __SEL(max, data); /* Parallel comparison of new samples and min */ (void)__SSUB16(data, min); /* Select min on each 16-bits half */ min = __SEL(min, data); pSize-=2; } /* Now we have maximum on even samples on low halfword of max * and maximum on odd samples on high halfword */ /* look for max between halfwords 1 & 0 by comparing on low halfword */ (void)__SSUB16(max, max >> 16); /* Select max on low 16-bits */ max = __SEL(max, max >> 16); /* look for min between halfwords 1 & 0 by comparing on low halfword */ (void)__SSUB16(min >> 16, min); /* Select min on low 16-bits */ min = __SEL(min, min >> 16); /* Test if odd number of samples */ if (pSize > 0) { data16 = *pSrc; /* put significant bits on bits 15-4 instead of 11-0 on low halfword */ data16 <<= 4; /* Write back to memory to have useable 16-bits sample */ *pSrc = data16; /* look for max between on low halfwords */ (void)__SSUB16(max, data16); /* Select max on low 16-bits */ max = __SEL(max, data16); /* look for min on low halfword */ (void)__SSUB16(data16, min); /* Select min on low 16-bits */ min = __SEL(min, data16); } /* Pack result : Min on Low halfword, Max on High halfword */ return __PKHBT(min, max, 16); /* PKHBT documentation */ }
With proper optimization options, I expect this to be quite efficient.
Yes, this is quite efficient!
It might be possible to gain 2 extra clock cycles per iteration by further unrolling, eg. processing four 16-bit samples at a time.
-It requires reading the vaiues contiguously.
Eg. if the two load instructions are next to eachother, then a clock cycle will be saved.
Another clock cycle is saved on the branch, we're saving.
Explained in detail; this sequence will save 2 clock-cycles:
load : load: process : process : store : store : branch
This sequence will only save one clock-cycle:
load : process : store : load : process : store : branch
(the end of the while loop represents the branch)
Each time the unrolling doubles, 2 clock cycles are saved until there are not enough free registers.
If we keep the DMA buffer's size divisible by 16 or a higher power of two, we do not need the 'cleanup' for the remaining values.
That would make the code a little simpler and easier to maintain.
You're right. Now that you have a efficient computation technique, you still can improve the overall efficiency.
Usually, I try to let compiler do his job where he's good !
In fact, you need to wonder what you can do to help him generate efficient code:
I made quite a detailed about this analysis on my blog (Simplest algorithm ever).
In the end :
- try to fix everything you can at compile time (bit shift count, buffer size, loop count ...)
- limit code visibility to what's necessary (using static functions will allow inlining optimizations inside a module), same for variables, do not use module variables (placed in RAM) when only local variables can be used
As demonstrated in my post, this will let you write safe code and allow compiler to get rid of unused parts !
All of this is only true when you need to reach best efficiency and can afford to turn compiler optimizations ON and very high !!
RAM usage looks great. There's plenty for placing code in SRAM in a section that does not collide with the DMA.As far as I can tell, the DMA buffer is somewhere in RamLoc128.That means you can pick any of the other ram locations (I'd suggest one of the AHB sections) for the code.Now, I just don't know which address RamLoc128 is.
Jens, if code will be run in SRAM the location should be at 0x10000000, the start of RamLoc128. It should be the data space and DMA buffer that must be relocated. This is because RamLoc128 (starting from 0x10000000) is the area where the bootloader copies and executes the image from SPIFI (and other external source) when not executing in place.
(I particularly like that NXP measure 0 Bytes in GB).
From your post above:
I needed to add the SPIFI Flash in order to use the Link2 as evaluation board (as described here: Introduction to Programming the NXP LPC4370 MCU Using the LPCxpresso Tools and Using Two LPC-Link2 Boards and here: Using an LPC-Link2 as an LPC4370 evaluation board | NXP Community
Using the LPC-Link2 with SPIFI Flash as the boot source is described in those two pages. What Jens is recommending is to execute from SRAM for the code to run faster. This means that you will add SPIFI Flash but program execution should not be directly from that location. The code from Flash should be copied to SRAM and executed there.
Yes, I completely agree: as I can see in LPCXpresso project's properties RamLock128 starts @ 0x10000000 (you can look for it in the picture posted my recap).
Next step on this front I'll try to do: understand how I can do this.
From my reply to Jens, the code should be run from 0x10000000, the start of RamLoc128. It should be the data space and DMA buffer that must be relocated.
Before Andrea posted what he is doing with the samples, this is not an advisable trick. Now that finding the minimum and maximum values seems the only task to be done, left-shift/change of scale is a simple but effective way of sign extension.
For this project, writing a custom function for searching the minimum and maximum values rather than using the CMSIS functions is more advantageous. This is because the input samples need to be sign-extended first and the search for minimum and maximum values can be combined in a single function.
... I know I asked info about floating point conversion so, I would be happy to give the correct answer to Goodwin cause his insight is great, but then I'd need to open up a new post to continue the interesting optimization discussion.
Please, let me know if a way is better than the other and what I should do, I really don't want to take advantage of anyone.
The floating point conversion did not solve your problem. I just thought it might help if we try to find a better way of converting the samples to floating-point format. You can mark one of Jens' or thibaut's reply as the correct answer since they provided high-caliber codes and tips on optimization. It's more than enough that you are very responsive and you acknowledged the effort of those who reply.
If you are planning to have expanded discussion regarding optimization, especially new question(s), it will be better if you open a new discussion about it.
In this project I need to use the ADCHS to sample gaussian-shaped impulsive signals like these:
I only have very very little knowledge about ionizing-radiations but I think signed data format is unwieldy for the type of signal you are processing. Perhaps the quantity you are measuring is somehow associated with energy. Anyhow it's quite unusual to use negative values for gaussian-shaped signal like this.
Yesterday there was an important update to the project and a collegue was able to tell me that we need at least 40 samples (or 128 on the entire 10us duration) per spike, so this acquisition can't be slower than roughly 1.25 Msps.
(Note that I still hope to be able to perform a 40Msps acquisition and understand how to get out the most from this micro, since this would open a whole set of possibilities for the applications of my project)
If you can use an unsigned data type for the samples I speculate that you can still gain improvement in processing speed. This is because you might be able to use the data from the DMA buffer directly, no need for sign extension. You can configure the ADC for offset binary format, pack 2 samples per word, and have bits 31 to 28 and 15 to 12 read as 0. In that case the maximum value will be the one closest to 4095 and the minimum value will be the one closest to 0. As can be seen from the plot there are only peaks and valleys there is no trench.
Many thanks goodwin for the insight on memory map. I'll try to combine your answers and jensbauer ones.As you suggest now I'm going to close this topic tomorrow (as soon as I can access the board and the thibaut's code) and see if open a new one on memory map/speed optimization as soon as I have more, detailed, infos.I'm sorry that I was unavailable in the last few days.
Thanks goodwin for your reply.I think you're right,
and that's similar to what we came up with using Thibaut's code: that's why I'm going to give him the correct answer.
But I'd like to thank you very much: you were the first to reply here on this post and I'm glad you did.
Speaking of my project:
Definitely, you're right. Unfortunately we have some trenches due to electronics artifacts from the analog circuitry and at the moment I don't know if I could get rid of them.But anyway, I can't get why switching to offset binary should make me gain in Dinamic Range on the positive side: isn't it still -2048 to 2047?Probably it is just me!
Thanks again for all your work, I'll follow your advice and eventually open a new post for my further questions.
Cheers,Andrea
Thank you Thibaut for your detailed answers.I studied and evaluated your code today and I got good results: it took roughly 22.5us for 128 32bit-data, so, correct me if I'm wrong, actually 256 samples! That's the same time it took with the previous implementation and without the bit shifting.
Usually, I try to let compiler do his job where he's good !In fact, you need to wonder what you can do to help him generate efficient code:I made quite a detailed about this analysis on my blog (Simplest algorithm ever).In the end : - try to fix everything you can at compile time (bit shift count, buffer size, loop count ...) - limit code visibility to what's necessary (using static functions will allow inlining optimizations inside a module), same for variables, do not use module variables (placed in RAM) when only local variables can be used
Thanks for this hints, I read the article you linked and now I think I better understand this new (to me of course) way to program your are showing: I feel like I need to study *a lot*. I just wonder how I can get those nice compiler outputs in GCC/LPCXpresso (which is actually a forked version of Eclipse).
Thanks again for your help! Now I'm going to close this post, but it was nice and helpful. Unfortunately I can choose just one correct answer, but I'd like to thank you all (once again) for what you are doing here. Lovely community.
You're welcome, very much too.
Maybe those are just noise of small amplitude not necessarily trenches.
Dynamic range is not the reason why I'm suggesting that you try using the offset binary format. With offset binary format the values of the samples will just be shifted (0 to 4095) but the range is still the same.
With binary offset, the user has flexibility in interpreting the output code. If the input signal is unipolar the output code can be treated as straight binary code (0X0..0 to 0XF..F unsigned). If the input is bipolar the output is a signed data format, you can convert to two's complement by simply complementing the leftmost bit or subtracting the offset if sign-extension is needed (when the destination is wider than the number of bits from the ADC). If the input is bipolar but level-shifted to become unipolar the user has freedom whether to treat the output code as straight binary or sign-encoded.
What I am suggesting you to explore is the possibility of avoiding to reformat the data from the DMA buffer. This is possible if your ADC output is in offset binary format and you configure the FIFO so that you always read 0s from bits 12 to 15 and 28 to 31. Then you will only need to search the minimum and maximum. In thibaut's code you can remove the statement
data <<= 4;
or the statement(s) that you used to sign-extend the data. Getting rid of that/those statement/s translates to faster execution and it avoids the unnecessary change of scale of the samples. Moreover, you have the freedom to choose between uint16_t, int16_t, or q15_t as the data type of the samples. Even if there is a possible hindrance in using the offset binary format I have less doubt that processing using two's complement code can only be as fast but not faster with offset binary format. Thus, it's worth exploring if you can avoid the two's complement format.
So, good luck on your thesis it's an interesting application of high-performance MCU.
I do totally agree with goodwin on this binary offset usage.
If further treatments can be tuned to work with this kind of data, it would improve your code nicely.
You would spare this shift operation and the write back to memory => this would lead back to the original SearchMinMax16_DSP code !
Thanks Goodwin for this advice!I now understand what you wanted to say, I'll speak with the analog/physic guys that I'm working with and I'll try to see if it's possible to get a unipolar signal!I know how to configure the offset binary and I think there should be a way to have always 0 before my samples, if not I hope that a bitwise "and" won't slow things down, but I'll see.I'm pretty sure I'll post again about this project so, let's say "see you soon"! And again, thanks for your help.
An AND operation will cost 1 clock cycle at least.
I will expect that it will stay at one clock cycle because the compiler should prepare the AND-mask before the loop starts.
The ADC, however, should always give you the same bit-values in the upper bits.
As far as I recall, the LPC4xxx can be configured to shift the bits to the top, which means you should be able to min/max those as most-significant instead of least-significant.
Thus you would not need to do any shifting or ANDing.
If the LPC4xxx always insert zeros at the bottom, when in this mode, this might be the most beneficial setting you can get (because the ADC value would be ready for use as a fractional value).
Even if the lower bits are 'rubbish', you can always clear those bits after the min/max loop, so it won't really cause any slow-down.
-I decided to investigate things, and in UM10503, section 46.6.2 and section 46.6.4, for GDR and DRx, it says:
When DONE is 1, this field contains a binary fraction representing
the voltage on the ADCn pin selected by the SEL field, divided by
the reference voltage on the VDDA pin. Zero in the field indicates
that the voltage on the ADCn input pin was less than, equal to, or
close to that on VSSA, while 0x3FF indicates that the voltage on
ADCn input pin was close to, equal to, or greater than that on
VDDA.
-So it's pretty clear: The result is aligned to the top of the 16-bit word. Your DMA should only transfer 16 bits from the DRx or GDR register.
The manual also mentions the following, which I believe is important in your case:
Remark: Use only the individual channel data registers DR0 to DR7 with burst mode or with hardware triggering to read the conversion results.
Thus the result is in the low 16 bits as follows (in binary): %RRRRRRRRRR000000, where R represents the 10-bit ADC Result.
So you don't need the AND or any bit-shifting; you get the fractional ADC result.
That means, when you've found your MIN and MAX values, you could multiply those values by 3.3 and divide by 65536.0, then you have the actual voltage (providing that the ADC reference voltage on the VDDA pin is 3.3V exactly.
If you prefer using integers (which is of course quicker), you can just multiply by 3300 and shift the result to the right 16 times, then you have millivolts. - but it should not be necessary to use integers in this case, as you'd most likely do that conversion on a PC, which is processing the captured data.
Jens, more likely you referred to an outdated version of UM10503. Currently there is Rev. 2.1 of the document
LPC43xx/LPC43Sxx ARM Cortex-M4/M0 multi-core microcontroller User manual.
Sections 46.6.2 and 46.6.4 for A/D Global Data register and A/D Data Registers are now in 47.6.2 and 47.6.4.
The information you posted apply to ADC0 and ADC1 which are 400 ksps, 10-bit ADCs. Andrea is using the high-speed (up to 80 Msps) 12-bit ADC (ADCHS). ADCHS is in Chapter 48 of UM10503 Rev. 2.1.
