Hi to you all,I've a firmware running on a NXP LPCLink2 (LPC4370: 204 Mhz Cortex M4 MCU) board which basically does this:
My problem is that my code is too slow, and every now and then and overwrite occurs.
Using the DMA I'm saving the ADC data, which I get in Twos complement format (Offset binary is also available), in a uint32_t buffer and try to prepare them for the CMSIS DSP function by converting the buffer into float32_t: here's where the overwrite occurs. It's worth saying that I'm currently using Floating point Software, not hardware.
The CMSIS library also accepts fractional formats like q31_t, q15_t and so on, and since I don't strictly need floating point maths I could even use these formats if that could save me precious time.It feels like I'm missing something important about this step, that's no surprise since this is my first project on a complex MCU, any help/hint/advise would be highly appreciated and would help me in my thesis.
I'll leave here the link for the (more datailed) question I asked in the NXP forums, just in case: LPC4370: ADCHS, GPDMA and CMSIS DSP | NXP Community .
Thanks in advance!
This is about the code that you posted in NXP Community.
Your code temporarily converts the negative ADC values to positive (by "manual" two's complementing) and eventually you convert back to negative by multiplying by -1. I suggest that you explore alternate, which can be more efficient, ways of converting from 12-bit signed integer to floating-point format.
A possible way of converting the ADC data from 12-bit signed integer to 32-bit floating-point format is by transforming to 32-bit two's complement code then assigning the result to a floating-point variable (simply let the compiler do the rest of the work).
If the ADC data is in (12-bit) offset binary code it can be converted to 32-bit two's complement format by simply subtracting the offset (in this case the offset is 2048)
adcBuff[i] - 2048
where adcBuff[] is an array of signed 32-bit integer (int32_t). We then let the compiler convert it into floating-point format by assigning to a floating-point variable. The complete statement would be
float32Buff[i] = adcBuff[i] - 2048;
where float32Buff[] is an array of 32-bit floating-point (float32_t) data.
If the ADC data is in 12-bit two's complement code it can be converted to 32-bit two's complement format by simply sign-filling bits 12 to 31 (replicating bit 11 into bits 12 to 31). Sign-filling can be done by (logical) shifting the 12-bit ADC data 20 bit positions to the left then performing an arithmetic shift right by 20 bit positions
(adcBuff[i] << 20) >> 20
Note that there is no test for the state of bit 11. I just can't clearly recall if I previously encountered a compiler which cancels (no corresponding code generated) opposing shifts like this. Including the assignment to a floating-point variable, the complete statement would be
float32Buff[i] = (adcBuff[i] << 20) >> 20;
If the compiler produces no code for the opposite shifts, you should devise a way to circumvent that or you can resort to alternative methods. An alternate method of converting the ADC data is to transform from 12-bit two's complement to 12-bit offset binary format. The subsequent conversion to 32-bit two's complement can be done as described above for the offset binary format. Two's complement code can be converted to offset binary format by simply complementing the leftmost bit (in this case bit 11)
adcBuff[i] ^ 0X00000800
The complete conversion statement would be
float32Buff[i] = (adcBuff[i] ^ 0X00000800) - 2048;
Hi goodwin,thank you very much for all your replies. You're right, in these days I figured out that fixed math is probably the way what I'm trying to do should be done.I read your reply about the float thought, and even if I don't have the time now to try it out (I "lost", actually used, too much time and I need to move forward since all this is for my thesis!), I got the idea and for sure I'd be back on your code in the future.
I just want to give some thoughts and suggestions which might be helpful to you.
Extremely helpful. What I do need more right now is an insight from a skilled eye to point out what could be possible limitation of my design.I'm not experienced so I read some chapters on this interesting book: The Definitive Guide to ARM® Cortex®-M3 and Cortex®-M4 Processors, Third Edition: Joseph Yiu: 9780124080829: Amazon.com:…
Here there are lots of useful information about the cycles needed for each operation and I'll try to do rough calculations about how many of them my code needs.I hoped I could squeeze things to fit in that 5 cycles boundary (which I was aware of since the beginning), but, as I understand, I might be wrong.Anyway, I'm planning to follow your advice and, since I'll need to sample impulsive signals, to use the ADCHS in non-continuous mode, using the thresholds I can set and processing data when no info is being sampled. What do you think about it?
Again, thank you very much: as I said I'm developing this alone and for the first time, therefore your help is highly appreciated.
Cheers,
Andrea
These are the possible reasons why you were lost:
float32Buff[i] = (adcBuff[i] & 0X00000FFF) - 2048;
float32Buff[i] = ((adcBuff[i] & 0X00000FFF) ^ 0X00000800) - 2048;
the order of AND and XOR can be interchanged
float32Buff[i] = ((adcBuff[i] ^ 0X00000800) & 0X00000FFF) - 2048;
Note that there is no change to the second statement, the inital settings of bits 12 to 31 will be lost with the shift to the left. The third statement is just for showing how to convert two's complement to offset binary format. In LPC4370 conversion of the ADC samples from two's complement to offset binary format in software is not needed since the ADC can be configured to output data in offset binary format.
I think that's the way to do it but as I stated I am not an expert. Instead I would further suggest that you access LabTool's documentation and open-source software. LabTool is also based on LPC4370/LPC-Link 2 so I hope you find it helpful to your thesis.
I did not follow the entire subject bu since my name is quoted here, I thought I would take a look !
Regarding speed comparison and optimization issues, can you tell which compiler you are using with which options ?
I you link with CMSIS_DSP library which is most likely built with ARM compiler (5, 6 ?) with high optimizations. Your code may not be comparable in terms of speed if built let's say with GCC !
If I caught your need properly, you need to detect min and max over a buffer of 12-bits signed integers ?
Can you show your computation code ?
Hi Thibaut, indeed I thought that since I'm evaluating your code it was proper to link your blog! And of course any hint from you would be welcomed. Actually I tried to reply to your questions in the section below trying to merge your answer with Jen's one.
That's right!And I believe that your implementation while save me a lot of computational time: I quoted the code in the answer below.
