Assembly programming - yes, no, when, how to start, ... ??
Hello again.
As I am very interested in learning ARM architecture, I would have few questions regarding assembly programming. Questions refer primarily to programming Cortex-M processors, because they are the only one which I am using (at least for now).
So... Do you program in C or assembly and why that? How do you suggest to start learning assembly programming? Do you think that the gain of execution time is big enough to justify time spent for assembly programming instead of C programming (with full optimization). Because in my case, processing time is quite important. Do you maybe only use intrinsics in special cases? Or inline/embedded assembly?
Every hint is very welcome and appreciated. Thank you in advance.
Regards,
Matic
