Hello.
I'm studying about the tail chaining of Cortex-M0.
Is it same as Cortex-M3 or M4?
Best regards.
have you referred to the https://community.arm.com/docs/DOC-2607 ?
It would be very helpful.
I think the mechanism of Cortex-M0's tail chainning is the same as Cortex-M4's.
The difference of the interrupt latencies would come from the differences of the internal bus architecture.
Cortex-M3/M4 has two AHB Lite buses for instructions and data, and instructions and data can be accessed simultaneously.
However Cortex-M0 has only one AHB Lite bus and a confliction between instruction and data accesses would cause extra latencies.
Best regards,
Yasuhiko Koumoto.
Hi, yasuhiko.
Thank you for your reply.
I read the page you mentioned once, but I was not ble able not to understand very well.
I’m not familiar with micro controllers, especially about the data bus.
I will keep trying to understand deeply what is written on that page.
Thank you again.
差出人: yasuhikokoumoto
日時: 2016年4月28日 13:59
宛先: 下田敏郎
件名: Re: - about tail chaning of Cortex-M0
reply from yasuhikokoumoto in ARM Processors - View the full discussion
Hello shimochan,
do you want to know what is the tail chaining?If it is correct, the tail chaining means that preveios context POP and a new context PUSH will be omitted if the CPU detect another interrupt before POPing the contexts.As you know one interrupt sequence takes as the following procedure.
<1> Detect Interrupt<2> Push contexts (r0-r3, r12,r14, r15 and xPSR)<3> Jump to ISR<4> Process ISR<5> Pop contexts (r0-r3, r12,r14, r15 and xPSR)<6> Return to the interrupted position
If the next interrupt detects at the <5> or later, the sequence wil be the following.
<1> Detect Interrupt<2> Push contexts (r0-r3, r12,r14, r15 and xPSR)<3> Jump to ISR<4> Process ISR<5> Pop contexts (r0-r3, r12,r14, r15 and xPSR)<*> New Interrupt<6> Push contexts (r0-r3, r12,r14, r15 and xPSR)<7> Jump to ISR<8> Process ISR<9> Pop contexts (r0-r3, r12,r14, r15 and xPSR)<10> Return to the interrupted position
Here, the contents of <5> and <6>, and the target stack would be the same.Therefore. CPU wants to omit the <5> and <6> processes to avoid the extra stack handling. If the next interrupt would come just before <5>, it would be possible.This is the tail chaining. After all, the interrupt sequence would become the following.
<1> Detect Interrupt<2> Push contexts (r0-r3, r12,r14, r15 and xPSR)<3> Jump to ISR<4> Process ISR<7> Jump to ISR<8> Process ISR<9> Pop contexts (r0-r3, r12,r14, r15 and xPSR)<10> Return to the interrupted position
As the results, 4 data push and 4 data pop (i.e. 8 cycles at the minimum) could be saved.Can this help you?
Best regards,Yasuhiko Koumoto.
