i am using stm32f7 and for debugging ulink pro, i have tried to enable ETM but not succeeded. the connector i am using is,
trace_D0 PC0
trace_D1 PC8
trace_D2 PD2trace_D3 PC12
i downloaded 2.4.0 tried running it on the above pins, not worked. but then i changed my pins on hardware to PE3 to PE6 and removed ini file, trace started working.
i came to know from a guy on keil forum that software pack (2.4.0) supports pins PE3-PE6, and i have to disable that option if i want to use the above mentioned pins and add ini file and initialze those pins in ini file. i have tried it but it is not working.
my ini file is
/*------------------------------------------------------------------- ** Define the function to enable the trace port **-----------------------------------------------------------------*/ FUNC void EnableTPIU(void) { _WDWORD(0x40023830, _RDWORD(0x40023830) | 0x00000004); // RCC_AHB1ENR: IO port PC 1,8,12 clock enable _WDWORD(0x40021000, 0x02020008); // GPIOC_MODER: PC1,PC8,PC12 = Alternate function mode _WDWORD(0x40021008, 0x0303000C); // GPIOC_OSPEEDR: PC1,PC8 PC12 = 100 MHz speed _WDWORD(0x4002100C, 0x00000000); // GPIOC_PUPDR: PC1,PC8 PC12 = No Pull-up/Pull-down _WDWORD(0x40021020, 0x00000000); // GPIOC_AFRL: PC1,PC8 PC12 = AF0 _WDWORD(0x40021024, 0x00000000); // GPIOC_AFRH: PC1,PC8 PC12 = AF0 _WDWORD(0x40023830, _RDWORD(0x40023830) | 0x00000008); // RCC_AHB1ENR: IO port D2 clock enable _WDWORD(0x40021000, 0x00000002); // GPIOD_MODER: PD2 = Alternate function mode _WDWORD(0x40021008, 0x00000003); // GPIOD_OSPEEDR: PD2 = 100 MHz speed _WDWORD(0x4002100C, 0x00000000); // GPIOD_PUPDR: PD2 = No Pull-up/Pull-down _WDWORD(0x40021020, 0x00000000); // GPIOD_AFRL: PD2 = AF0 _WDWORD(0xE0042004, 0x000000E0); // Set 4-pin tracing via DBGMCU_CR _WDWORD(0xE000EDFC, 0x01000000); // _WDWORD(0xE00400F0, 0x00000000); // _WDWORD(0xE0040004, 0x00000008); // _WDWORD(0xE0001020, 0x002002CA); // _WDWORD(0xE0001024, 0x0000000); // _WDWORD(0xE0001028, 0x00000008); // _WDWORD(0xE0041004, 0x00000000); // _RDWORD(0xE004100C, _RDWORD(0xE004100C) | 0x00000003); // _WDWORD(0xE0041040, 0x00000002); // _WDWORD(0xE0041080, 0x00000001); // _WDWORD(0xE004108C, 0x000000FF); // _WDWORD(0xE0041004, 0x00000001); // } /*------------------------------------------------------------------- ** Invoke the function at debugger startup **-----------------------------------------------------------------*/ EnableTPIU(); /*------------------------------------------------------------------- ** Execute upon software RESET **-----------------------------------------------------------------*/ FUNC void OnResetExec(void) { EnableTPIU(); }
i have changed the core clock to 180MHz.
Where am i doing it wrong ?
Thank you
Bilal
Is the PC0 is a typo of PC1, isn't it?
I am not familiar with the Cortex-M ETM.
You seems not to set TRACE clock.
Is it OK?
The TRACE clock is assigned to PE2.
Best regards,
Yasuhiko Koumoto.
