I would like to know if there is any tool for migrating from ARM mcu's to Atmel? can any one help me on this topic?
Hello Norman,
what kind of tool are you looking for? Do you want to port your code or something else? My colleague jyiu has written some migration guides. But as far as I know only for PIC and 8051 (at least for microcontrollers). Maybe our learning page can help you: Cortex-M Learning Platform
Kind regards,
Christopher
Edit: I just saw that you are looking for a migration guide to Atmel - I don't think that you will find that here
Dear Christopher, Thanks for your reply. Actually what I am looking for is some type of tool or software that I can use to migrate my design from 168 MHz Cortex M4F CPU (256 KB RAM, 2 MBFlash) to AVR Atmel products. I want to redesign a similar product using AVR and I need to have the code transferred to the new mcu. Can you please guide me on that, or if your colleague Jyiu can give me some information.
RegardsNorman
Hi Norman,
Atmel have Cortex-M4 products as well
SAM4S ARM Cortex M4 MCUs
andalso Cortex-M7 based products
SAM E MCUs
Since they are the same architecture the migration should be fairly easy.
regards,
Joseph
I know of no such tool, but I'd like to let you know that since the AVR is 8-bit, you might run into some problems, especially if you need to write more than 8 bits on a port in one go.
Also, as far as I know, the AVR's maximum clock frequency is 20 MHz.
If you do not need high speeds and writing more than 8 bits on a port at once, then you may be able to pull it off.
If you're migrating because you've found some low-cost AVR, then I'd like to mention that you can get ARM microcontrollers for less than $1.
If you're migrating because you need to run it at 5V, both Freescale/NXP and Cypress make 5V ARM Cortex-M3 microcontrollers.
If you migrate because you need DIP and easy soldering or socketing, then NXP have the LPC8xx and LPC1114.
I'm not trying to change your mind, but I'd like to let you know that there are several choices, when it comes to ARM based microcontrollers in the hope that it might make your job easier.
For instance, you can search Farnell's Web-site for Cortex-M and sort by price. Mouser Electronics and Digi-Key also have a lot of Cortex-M MCUs.
Anyway, if you decide to port the design, I think you will need to do it manually (you'll need to know how the hardware works anyway). I wish you good luck with it, whichever path you choose.
Dear Chritopher
Thank you very much for your informative and comprehensive response. It was
quite helpful for me to make my decision. I appreciate you and hope to
receive your further feedbacks regarding my questions. I would appreciate
if I can have your Skype and email so that when I face such technical
problems, I can share them with you.
Regards
Norman
SkypeID: normanmedi
Dear Joseph
Thanks for your reply and it was very informative. You have mentioned that the migration is simple, can you please also guide me on that?RegardsNorman
Dear Jens
Thanks a lot for spending your time and providing me with a through and complete guide. I appreciate and it was quite helpful. I got your points and I have to rethink about my plan base on what you said.RegardsNorman
