Reduce ARM CM0+ scatter initialization during boot?
We are using ARM CM0+ in our embedded SoC design and I noticed that boot takes a long time. Specifically, I saw that it took ~18K cycles after the unreset before we executed an instruction that I recognize (which is inside __rt_entry). We are of course using the CMSIS RTX RTOS on the CM0.
It appears from an RTL simulation that during 18000 cycles, the MCU is mostly inside a tight loop of 4 instructions. The PC keeps going looping across 0x178->0x17a->0x17c->0x17e->back. This is most likely some zero initialization (BSS?). The armlink generated .info suggests that the PC is inside !!handler_zi which is inside the object: c_p.l (__scatter_zi.o). This comes from ARM/sw/ARMCompiler5.05u1/lib/armlib/c_p.l.
Questions
- how do I find out what is being initialized?
- how do I not initialize (if not required in our design)?
The scatter text file is very simple and copy-pasted below.
Thanks in advance!!
LOAD 0x0000  SRAM_SIZE
  EXEC_ROM_VECTOR_DATA +0
      startup_ARMCM0.s.o(RESET)
    EXEC_ROM_VECTOR_HANDLERS +0
      startup_ARMCM0.s.o(.text)
    EXEC_ROM +0
        *(+RO)
    EXEC_RAM +0
        *(+RW)
    EXEC_ZI +0
        *(+ZI)
    HEAP +0
      startup_ARMCM0.s.o(HEAP)
    STACK +0
      startup_ARMCM0.s.o(STACK)
