Cortex-M7 load instruction latency and pairing
What is the latency for the LDR instruction when the result is used for integer arithmetic operations (for example DSP MAC instructions)?
Also, can 64-bit loads (LDRD) be paired with another instruction? Can I do for example a 64-bit load and an integer MAC at the same time?
I hope ARM will add the latencies and more detailed pairing information to the reference manual soon.
Antti
