Question about bit-banding for Tiva M4 core
I read example projects of Tiva-C 1294. There are many similar uses '    GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_2, GPIO_PIN_2);'
The prototype is :
extern void GPIOPinWrite(uint32_t ui32Port, uint8_t ui8Pins, uint8_t ui8Val);
The last parameter is a value, not a pin. I have asked the question on TI forum. I know that it is bit-banding, but that answer lacks detail on why it is bit-banding, it is set to '1' or clear to '0'?
Could you tell me more the line on GPIO_PIN_2?
Thanks,
void EK_TM4C1294XL_initWiFi(void)
    /* Configure EN & CS pins to disable CC3100 */
    GPIOPinTypeGPIOOutput(GPIO_PORTH_BASE, GPIO_PIN_2);
    GPIOPinTypeGPIOOutput(GPIO_PORTC_BASE, GPIO_PIN_6);
    GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_6, 0);
  • I do not know so much about what the GPIO pins are connected to, but I might be able to provide some more information on bit-banding.
    I think, though, that...
    ...should have been...
    GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_2, 1);
    ... I'm convinced it would do the exact same thing, as I expect GPIO_PIN_2 to be non-zero.
    -That is, of course, if the function is a true bit-banding function.
    If it's just using data and masks, then GPIO_PIN_2 would be correct.
    In any case, the line for GPIO_PIN_2 will set GPIO pin 2 on Port H to high.
    Bit-banding is a different way of addressing, so that you can change a single bit on one go, instead of reading a whole byte, change it and write it back.
    For instance, a device might have an on-chip SRAM starting at 0x20000000 and a Bit-band region starting at 0x22000000.
    If you want to set bit 3 in address 0x20000000, you could do it this way:
    1: read contents of address 0x20000000 into a variable or register
    2: change bit 3
    3: write the variable or register's value back to address 0x20000000
    -But instead, you could use bit-banding.
    You just need to write a non-zero value to address 0x22000004 in order to set the bit.
    Writing a zero to the same address clears the bit.
    Thus the above function will do it all for you; it only changes a single bit at a time, leaving the other bits untouched.
    -You don't have to do any calculations in order to access the bitband if you use the function.
  • Hello,
    I think the statements are not related with the bit-banding.
    I think they are just GPIO settings.
    I guess that GPIO_PIN_2 would be 0x4 (i.e. bit2 is 1).
    So,
    means set GPIOH[2] to '1'.
    Also,
    means set GPIOC[6] to '0'.
    Best regards,
    Yasuhiko Koumoto.
