Question about bit-banding for Tiva M4 core
I read example projects of Tiva-C 1294. There are many similar uses '    GPIOPinWrite(GPIO_PORTH_BASE, GPIO_PIN_2, GPIO_PIN_2);'
The prototype is :
extern void GPIOPinWrite(uint32_t ui32Port, uint8_t ui8Pins, uint8_t ui8Val);
The last parameter is a value, not a pin. I have asked the question on TI forum. I know that it is bit-banding, but that answer lacks detail on why it is bit-banding, it is set to '1' or clear to '0'?
Could you tell me more the line on GPIO_PIN_2?
Thanks,
void EK_TM4C1294XL_initWiFi(void)
    /* Configure EN & CS pins to disable CC3100 */
    GPIOPinTypeGPIOOutput(GPIO_PORTH_BASE, GPIO_PIN_2);
    GPIOPinTypeGPIOOutput(GPIO_PORTC_BASE, GPIO_PIN_6);
    GPIOPinWrite(GPIO_PORTC_BASE, GPIO_PIN_6, 0);
  • Hello,
    I think the statements are not related with the bit-banding.
    I think they are just GPIO settings.
    I guess that GPIO_PIN_2 would be 0x4 (i.e. bit2 is 1).
    So,
    means set GPIOH[2] to '1'.
    Also,
    means set GPIOC[6] to '0'.
    Best regards,
    Yasuhiko Koumoto.
  • Hello,
    So,
    Also,
    Best regards,
    Yasuhiko Koumoto.
