I had a small program which was run on a CM4 and it was using semihosting.
The code works fine wiht 4.9.3 q1 2015.
When I picked the latest 4.9.3 q2 2015 the program fails to run.
It cannot allocate memory from heap.
So I tried a sample form 4.9.3 for semihosting it also did not give expected output.
I would like to know
1. What changed ?
2. Some good tips for semihosting debugging.
Regards,
N
if you say about GCC ARM Embedded, you can refer to https://launchpad.net/gcc-arm-embedded/4.9/4.9-2015-q2-update .
I'm sorry if you had already done it.
By the way, do you have any reason why you should use the latest version?
Best regards,
Yasuhiko Koumoto.
