Greetings,
sir/madam i am working on xmc4100 after reading the reference manual i am tried to configure the clock (CCU) which was present under system control unit (SCU). my external crystal is 12mhz, i didn't get proper clock at the output. may i know the correct procedure to configure the clock???
Thanks and Regards,
Harshan.
I've not worked with XMC4100, but normally when I configure the clock, I do things in this order:
That's approximately it. I generally go through all the hardware registers regarding the clock configuration, and ensure that their values are correct.
