Hello!
I finally decided to share some info about a project I've been doing for the past 8 months. Currently it can be considered "alpha" or maybe "early beta" stage, but - despite literal meaning of these terms - the things that are already done (and there's quite a lot of them) work pretty well and are thoroughly tested. The only architecture supported at the moment is ARMv7-M, so ARM Cortex-M3 and ARM Cortex-M4(F). The only "officially" supported chip is STM32F407VG (the one found on the first STM32F4DISCOVERY board).
The whole project is written in C++11 and there is no C API. Such C API is of course planned and it will be pthread, maybe one more, a bit more "native", which would allow better/easier access to unique features of this project. Anyway - the C++11 API that is currently available aims for 100% compatibility with POSIX (in features, not in names). It is worth noting that the code DOES NOT use dynamically allocated memory, so EVERYTHING (especially threads and their stacks) can be constructed as local variables (on stack), global variables or however you like it.
Another important thing worth noting is that this project doesn't aim to be "the smallest" and/or "the fastest" RTOS. As the time passed (and as powerful chips with with lots of RAM got more popular and cheaper (; ) I came to a conclusion that all extreme measures taken in other projects just to save a few clock cycles or 10 bytes of memory are not justified at all. What I'm saying here doesn't mean that this code runs pathetically slow and uses whole available memory (; I just don't devote all my attention to such optimizations - I focus on these matters in the "right" proportion (;
Here's a link to project's official website:
distortos | advanced real-time operating system for deeply embedded targets
Here is a link to github repository:
DISTORTEC/distortos · GitHub
And here's an article I wrote on my page about the current state of this project:
distortos - 7 months & 0x3FF commits! (it is also available in Polish).
I'm pasting the article below, but anyone interested is encouraged to visit the link above, because the original text has a lot of clickable links to relevant source files in the repository.
distortos - 7 months & 0x3FF commits! (Sunday, 22 February 2015 20:52) distortos project - mentioned in previous news article - is still evolving. Today it is exactly 7 months since the first commit in the repository, and the total number of these commits reached a nice value of 1023. Many readers - at least those who are a bit into RTOSes for microcontrollers - may wonder "who needs another RTOS project?". Answer to this question is very complex and I could write a separate article about that, so for now a link to README file - in which I tried to explain the main reasons for this project's existence - must suffice. I think that at least the huge emphasis placed on C++ and C++11 support makes this project worthwhile, although this feature should not diminish other advantages (some of which are of course "future" (; ), important for people who don't intend to use C++ (this feature is one of the "future" ones for sure, as for now only C++11 API is available). There are still many features missing, but these 7 months were well spent - quite a lot was done, and these things work remarkably well (; The most important features are obviously threads (Thread, StaticThread and ThreadBase classes), which can accept any number of arguments of any type - thanks to new features of C++11 standard - not only the void* known from other RTOSes. Moreover - regular functions, member functions, functors or lambdas can be used as thread's function. All of these features are also present in software timers (SoftwareTimer class). Scheduler supports full preemption based on thread's priority (there are 256 priority levels), and when several threads with the same priority are present, they are scheduled according to FIFO or round-robin algorithm (selected for each thread individually). Semaphore (Semaphore class) is probably the most basic synchronization object. It is possible to configure maximal value the semaphore can "have", so this object can also be used as binary semaphore. Semaphores can be "posted" from interrupts. Mutex (Mutex class) is one of more advanced synchronization mechanisms. Just as in POSIX standard, it can be configured to use any of the three "modes" - normal, error-checking or recursive - and any of the three "protocols" - normal, priority inheritance or priority protocol (also known as priority ceiling). Unlike many other RTOSes, priority inheritance protocol works with no limitations: through any number of inheritance "levels" and with any number of mutexes locked by threads in any order (diagram and description of test case of this particular feature). Classic condition variable (ConditionVariable class) is a mechanism which extends functionality of mutexes. Queues can be used for standard communication between threads and interrupts (in any combination). There are four variants of queues: - without priorities, without support for objects (RawFifoQueue and StaticRawFifoQueue classes), - without priorities, with support for objects (FifoQueue and StaticFifoQueue classes), - with priorities, without support for objects (RawMessageQueue and StaticRawMessageQueue classes), - with priorities, with support for objects (MessageQueue and StaticMessageQueue classes). Messages added to queues which don't support priorities (...FifoQueue) are ordered in FIFO order, while queues which do support priorities (...MessageQueue) allow adding messages with one of 256 priority levels. Queues without support for objects (...Raw...) copy the messages with memcpy() function, while queues with support for objects use all operations required in such scenario (construction, destruction, assignment operator, swap, emplace, ...). All blocking operations are also available in non-blocking variants and in blocking versions with timeout (absolute or relative), which - thanks to C++11 std::chrono - can be easily expressed in any unit (like seconds, minutes, hours, ... - link), not only in system "ticks". All errors are signaled with error codes - functions use neither errno variable, nor C++ exceptions. The only supported architecture - for now - is ARMv7-M, so ARM Cortex-M3 and ARM Cortex-M4(F), and the only "officially" supported chip is STM32F407VG (known from STM32F4Discovery board), although using any different chip with proper core would be trivial. I saved the best part (I hope) for the end - use of all functionalities mentioned above is possible without dynamic memory allocation. All previously described objects can be constructed as global variables or on stack. I'm sure I forgot to mention some more interesting features... Feel encouraged to test the code, ask questions, post comments, send suggestions and cooperate (; Stay tuned!
An finally - a small news article with a teaser - Work in progress...
The simplest thread doesn't require ANY configuration, because main() function is already a thread! So here's the immortal LED blinker in the shortest form:
#include "distortos/ThisThread.hpp" int main() { // --- configure your GPIO pin here --- while (1) { // --- toggle the state of GPIO here --- distortos::ThisThread::sleepFor(std::chrono::milliseconds(500)); } }
Compilation result
text data bss dec hex filename 4924 100 4840 9864 2688 ./output/distortos.elf
2kB of RAM is the stack for main() and another 2kB is the stack for interrupts. These two numbers are obviously too much for such a simple program, so they can be reduced with no problems.
If you'd like to have a separate thread it's still pretty simple:
#include "distortos/StaticThread.hpp" #include "distortos/ThisThread.hpp" void blinkFunction() { // --- configure your GPIO pin here --- while (1) { // --- toggle the state of GPIO here --- distortos::ThisThread::sleepFor(std::chrono::milliseconds(500)); } } int main() { auto blinkThread = distortos::makeStaticThread<512>(1, blinkFunction); blinkThread.start(); return blinkThread.join(); }
Size of stack for the thread (512 bytes) and its priority (1) are not based on any deep reasoning - just some two values that will make the code work in an expected way (unless the GPIO configuration or toggling would use functions that use a lot of stack). The priority can be changed in 0-255 range, but 0 is not a very good option, as it's the priority of idle thread.
text data bss dec hex filename 6084 1144 4880 12108 2f4c ./output/distortos.elf
Most of the used RAM (almost everything above the 2kB + 2kB for stacks mentioned above) is used by newlib's module with maloc() and free(), which is pulled into the link because of free(). This code doesn't allocate a single byte of memory from the heap.
Regards,
FCh
Welcome to the community, Freddie.
-I've been hoping for a long time you would join us; I am very sure you'll like it here.
This looks quite neat. Although I don't know much about RTOS, but I know the basics.
The size of the binary does not look too scary; I've seen far worse.
jensbauer wrote: The size of the binary does not look too scary; I've seen far worse.
jensbauer wrote:
Well, there's not much code in these examples, so some people may argue that anything above 100 bytes of flash and 20 bytes of RAM is way too much (;
I am an "optimist" myself, working very much with optimizing assembly language, and I don't mind.
If I'm lucky, I might be able to contribute with a few small things.
Hello Freddie,
a very interesting project! Have you thought about creating a Software Pack for it to make it more publicly available to users of MDK? You could host the Pack on your web space, but if you provide the package description file (PDSC) to us (cmsis@arm.com), we could create an entry on our index server so that all users of Keil MDK Version 5 would be aware of this newly created RTOS. If you have further questions, please do not hesitate to contact me directly.
Kind regards,
Christopher
I would have loved to have this kind of ideas few years before.
Congratulations and good luck to you.
Hmm... This sounds very interesting and tempting, but this project - currently - supports only GCC with newlib. Wouldn't this be a problem?
C++11 has some really great features for small embedded microcontrollers - the most important C++11-only features I use in this project are variadic templates and move semantics, which are essential to the implementation of threads (and software timers) with any number of arguments of any type. But there are of course a lot more. But the standard is not enough - for example some time ago GCC didn't like the idea of polymorphic object being ROM-able, but this was fixed in GCC 4.7. Even now there are some things that need a really recent compiler version to work correctly or to work at all - to use "emplace" functions with queues in distortos you need to use GCC 4.9, as previous versions didn't support pack expansion in lambda functions, which is essential to the way "emplace" functions are implemented*... What I mean with this paragraph, is that the "idea" is not enough - this project couldn't exist without C++11 standard _AND_ without good support for C++11 in toolchain. So I guess that "few years before" this wouldn't be possible or wouldn't be so nice (;
* - this could be implemented in some other ways, but implementation with lambda is much simpler, while the "other" method would either require enabling C++14 or reinventing some pieces of C++14 standard library ( std::integer_sequence - cppreference.com )
It really sounds like you would find the D language interesting; in particular creating a bare metal toolchain.
Personally, I have not succeeded in creating the toolchain I dream of: GCC w/C,C++,ObjC and GDC.
I think I got stuck when I wanted to use multilib with GDC - the solution might be simple, though.
I've heard about D - I even participated in their forums some time ago (; There are some great ideas in D, but from what I understood back then (maybe I was wrong or maybe this is no longer true) there is no way to use their library without garbage collection and porting this library for a microcontroller would be extremely difficult. This link is more interesting - Minimal semihosted ARM Cortex-M "Hello World" - D Wiki (; But the "todo" item at the bottom - "port D runtime" - is probably still on someone's "todo" list... Without the library, D is nothing more than a fancy syntax...
Actually that was the link I intended to post in the first place, but you knew already.
Notice which interface he's using; - that's a clever guy.
I'm not really using a 'runtime' myself; I use my own startup.c, which contains the exception vectors and a minimal Reset_Handler.
However, that's for C.
Update: It seems the runtime is in progress: Embedded D, top down?
Hello again!
It's been one year (and a few days) since I started development of distortos project (; Recently I've added just two new features: first one is an equivalent of std::call_once() / pthread_once() and the second one - really worth mentioning - is a support for POSIX signals (both synchronous and asynchronous). This second feature is - in my opinion - pretty rare in RTOSes for microcontrollers, as I know about just two other projects that have it. I wrote a little more on my personal webpage, so anyone interested is encouraged to check this short news article -> distortos is one year old!
If anyone is wondering, the project is not dead (; Actually a month ago I finally published the very first version - 0.1.0 - which you can download from distortos website > Downloads. The release of the RTOS is accompanied by a package with project template (distortosTemplateSubfolder) and a package with a few examples (distortosExamples) - currently just the immortal LED blinker, this time using threads (;
On the website you can also find complete change log of the release, which highlights some of the most important features.
Pretty soon there will be another release, with support for ARMv6-M (ARM Cortex-M0, ARM Cortex-M0+ and ARM Cortex-M1), so stay tuned (;
Absolutely cool!
Am I right in that it proves it's threaded by going slightly out of sync ?
In this examples there are 4 threads, each toggles its LED and then goes to sleep for a predetermined period of time. The periods for different threads are slightly different - the lack of synchronization between threads was done on purpose, because it looks really nice (;
See here -> distortosExamples/staticThreadBlinker.cpp at master · DISTORTEC/distortosExamples · GitHub . At lines 110, 115, 120 and 125 the duration passed to the threads are different. Actually the values are adjacent prime numbers <:
It would be trivial to make the blinking identical by using distortos::ThisThread::sleepUntil() with constantly updated wake-up time, but 4 LEDs blinking exactly the same seemed too boring (;
I agree completely - who wouldn't.
-But if using identical delays, wouldn't waiting a couple of years show that they would go out of sync ?
