Reset problem with stm32f4
My board consists of stm32f427 and I have a strange problem.
Calling NVIC_SystemReset() causes CPU to hang. This happens only on some boards.
I could overcome the problem in one of the following:
  1. Add a HAL_Delay(100) before calling NVIC_SystemReset()
  2. Change code in NVIC_SystemReset() as follows:
       SCB->AIRCR = ((0x5FA << SCB_AIRCR_VECTKEY_Pos) |
                                 (SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) |
                                 SCB_AIRCR_SYSRESETREQ_Msk
                                 SCB_AIRCR_VECTCLRACTIVE_Msk | SCB_AIRCR_VECTRESET_Msk)
     These 2 additional bits cause CPU to reset, although they are meant to be used only for debug
  3.  Of course system will reset if I use the IWDG.
I read in forums that others encountered this problem but in my case it looks different:
  • NRST pin has a pulldown 0.1uF.  NRST is not pulled up. As shown below in figure
  • BOOT0 is connected to ground.
Could anyone please explain:
Why NVIC_SystemReset() does not work on some boards?
How solutions 1 and 2 bypass the problem?
Thank you,
Ari
