SWD cannot read/write MEM-AP
I try to use SWD protocol connect with ARM Cortex-M0.
The first step I read IDCODE register:
  • Send more than 50 SWCLKTCK cycles with SWDIOTMS=1. This ensures that both SWD and JTAG are in their reset states.
  • Send the 16-bit JTAG-to-SWD select sequence on SWDIOTMS. Write 0x79E7.
  • Send more than  50 SWCLKTCK cycles with SWDIOTMS=1. This ensures that if SWJ-DP was already in SWD mode, before sending the select sequence, the SWD goes to line reset.
  • Perform a READID to validate that SWJ-DP has switched to SWD operation.
I can read it. IDCODE=0x0BB11477.
The second step I set CDBGRSTREQ and CDBGRSTACK (bits 28 and 29) in the CTRL/STAT (address 0x4) register of the DP.
But when I try to read IDR register, it's only answer 0x00. The right answer is 0x04770021. I don't know what I'm missing?!
Please help me fix its!! Thanks you very much!
