I am trying to enable MPU on peripherals to allow them only for only privileged access and trying to access from an unprivileged thread.
All address range works well except ITM(Instrumentation Trace Macrocell) address space.
I am working on STM32F429-Cortex M4, I am not sure is it about ST's MCU or Arm Cortex M Core
I am setting the MPU for the whole peripheral range at a time.
The ITM address is 0xE0000000
If "address < 0xE0000000" MPU WorksIf "0xE0000000 < address < 0xE0010000" Unprivileged Thread Can Read : FAILUREIf "0xE0010000 < address < 0xE0100000" BUS FaultIf "0xE0100000 < address" MPU WorksIs there any limitation on MPU for ITM address space?
Kind Regards,
Murat
The MPU cannot modify some attributes of the default memory map
If the ITM is disabled or not implemented, a write to a stimulus port must not cause a BusFault exception. This ensures the ITM is transparent to application software.
The Trace Privilege Register defines whether each group of eight Stimulus Port registers (32 implemented in Cortex-M4), and their corresponding Trace Enable Register bits, can be written by an unprivileged access. Unprivileged code can always read the Stimulus Port registers.
