How does cortex-M33, for example, know previous exception priority?
Hello
I want to know about exception priority.
In following situation
  • A has highest priority, described as priority A.
  • B has medium priority, described as priority B.
  • C has lowest priority, described as priority C.
when following sequence is occurred.
  1. CPU runs in thread mode
  2. Exception C occurs. The CPU enter the handler mode. And the execution priority is priority C.
  3. Exception B occurs. The execution priority is priority B.
  4. Exception A occurs. The execution priority is priority A.
  5. When ISR for Exception A reaches end of task so use EXC_RETURN to return exception.
  6. Now execution back to ISR for B and the execution priority might be priority B.
My Question is how does the Cortex-M33 know correct priority number(priority B in above sequence #6)
Regards,
Susumu
