Fail to add JTAG/swd debug into Cortex-M0
I have been trying to add the debug function into my Cortex-M0 design for FPGA implementation targeting at Xilinx Spartan-6.
Both JTAG or SWD are failed to work although the cortex-m0 seem function well (it execute the code and make LED blinky).
What I do is setting the configuration in CORTEXM0INTEGRATIONIMP.v ( yes, I started from the wrapper file) to enable its debug function and JTAG (or SWD in another try), and adding the necessary file under the logical directory and model directory directly. I used the built-in ROM table, so I didn't modify the BASEADDR in CORTEXM0INTERGATION.v. And I add the code in top level module to use TDOEN to control the TDO output (just like what Integration Kit does). When I implement the design in ISE, the TDI, nTRST, TCK, TMS, and TDO was removed in the map phase by the ISE. Then the DS-5 and MDK can't detect the existing of debug port.
I know ARM have offer two Altera FPGA images that support SWD and JTAG in Application Note 226 (ARM DAI0226B). I would like to know if there exist any document to teach people to add the debug port into Cortex-M0. Is overriding the dap model under the model directory a necessary work?
Thanks for your help!
