Hi,project VScode PIO, ATSAM3X8, Framework Arduino.simple bootloader on Flash, loader code in RAM call code, execute.load code call direct ( my entry_main_ram) 0x20000000 area ok.
see: run ok , file flash.ld and sram.ld compiling separately (flash)
code in bootloader main flash{
typedef void(*entry_function_t)( void);
loader code in ram...ok entry_function_t entry_exe = entry_exe = (entry_function_t) entry_main_ram; for call
entry_exe(); call ram code
//-------------program in RAM running ok
void entry_main_ram(){ it in area RAM running ok uint32_t led =0; while(1){ digitalWrite( L1, led ); led ^=1; } } //---------------------- problems violation cause reset processor, program in RAM execute code void entry_main_ram(){ bool bl = true; while(1){ digitalWrite( L1, bl = !bl ); not effects, in flash ok set_invert_led(); simple call reset processor } } //---------------------see list call reset processor Serial.begin(9600); //reset processor pmc_enable_periph_clk(ID_CAN0); //reset processor can_init(CAN0, 84000000, 500); //reset processorin short, all calls outside the function cause an error or have no effect on variables.
thanks,Carlos.
