SPI hanging up
Hello!
I am trying to use SPI between my ATSAMD21G18A (Cortex M0) as master and a radio module as slave. I am able to initiate the SPI, but having trouble enabling the receiver (RXEN). The manual states:
Writing a one to CTRLB.RXEN when the SPI is disabled will set CTRLB.RXEN immediately. When the SPI is enabled, CTRLB.RXEN will be cleared, SYNCBUSY.CTRLB will be set and remain set until the receiver is enabled. When the receiver is enabled CTRLB.RXEN will read back as one.
After enabling the SPI, SYNCBUSY.CTRLB is always set to one and the receiver is not being enabled.
My suspicion is that I'm wrongly configuring the clocks for the SPI. Here is the code below for the clocks and SPI configuration I have.
    /* Enable clock for SPI */
    PM->APBCMASK.reg |= SPI_BUS_CLOCK_INDEX;
    GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID(SERCOM4_GCLK_ID_CORE) | // Generic Clock for SERCOM4
                  GCLK_CLKCTRL_GEN_GCLK0 | // Generic Clock Generator 0 is source
                  GCLK_CLKCTRL_CLKEN;
    while ( GCLK->STATUS.reg & GCLK_STATUS_SYNCBUSY )
	        /* Wait for synchronization */
	while(SERCOM4->SPI.SYNCBUSY.bit.ENABLE);
	/* Disable the SERCOM SPI module */
	SERCOM4->SPI.CTRLA.bit.ENABLE = 0;
	while(SERCOM4->SPI.SYNCBUSY.bit.SWRST);
	/* Perform a software reset */
	SERCOM4->SPI.CTRLA.bit.SWRST = 1;
	while(SERCOM4->SPI.CTRLA.bit.SWRST);
	while(SERCOM4->SPI.SYNCBUSY.bit.SWRST || SERCOM4->SPI.SYNCBUSY.bit.ENABLE);
	/* Update the SPI pad settings, mode and data order settings */
	SERCOM4->SPI.CTRLA.reg = pad_conf | SERCOM_SPI_CTRLA_MODE(3);	//SPI in master operation (0x3)
	SERCOM4->SPI.CTRLA.bit.DORD = 0;		//Data order MSB first
	SERCOM4->SPI.CTRLA.bit.CPOL = 0;     //Clock polarity
	SERCOM4->SPI.CTRLA.bit.CPHA = 0;     //Clock phase
	SERCOM4->SPI.CTRLA.reg = SERCOM_SPI_CTRLA_FORM(0);	//format
	while(SERCOM4->SPI.SYNCBUSY.bit.CTRLB);
	SERCOM4->SPI.CTRLB.bit.RXEN = 1;
	uint8_t baud_val = 250;
	SERCOM4->SPI.BAUD.reg = baud_val;
	/* Enable SERCOM SPI */
	SERCOM4->SPI.CTRLA.bit.ENABLE = 1;
	while(SERCOM4->SPI.SYNCBUSY.reg & SERCOM_SPI_SYNCBUSY_ENABLE);
Any help is appreciated!
Best regards,
Barry
