Hello everyone, i'm working on NVIC, i need enable the TIMER2 IRQ, but without CMSIS HAL, just native C code, so i have got this:
#include "NVICDriver.h" #include <stdint.h> #include <string.h> #define BASE_ADDRESS_VECTOR_TABLE 0x00000000 static uint32_t* NVIC_ISER0 = 0x10000000; static uint32_t* NVIC_ICER0 = 0x18000000; typedef void(*vect_func)(void); static vect_func vector_table[1] = { TIMER2_IRQHandle }; void NVIC_Init(){ *NVIC_ISER0 |= 0x001C; //tmr2 enable interrupt IRQ 28 *NVIC_ICER0 &= 0x00000000; //Clear flags memcpy((BASE_ADDRESS_VECTOR_TABLE+0xB0), vector_table, sizeof(vector_table)); }
As you can see, first i enable the IRQ on NVIC_ISER0 (IRQ28 = TMR2 so my register is NIVC_ISER0, isn''t it? after that, i clear interrupts, and I copy to vector table just the function what i want! (0xb0 is the offset into the vector table where the TIMER2 is from)
What's wrong on this?
the function TIMER2_IRQHandle should be pointing to the TIMR2 Vector addres really? i trie to turn on LED (timer is is configured) but it doesn't work
UPDATE:
I just try this:
#define EnablePrivilegedMode() __asm("SVC #0") #define BASE_ADDRESS_NVIC 0xE000E000 #define OFFSET_ISER0 0x100 #define BASE_ADDRESS_IABR (BASE_ADDRESS_NVIC+0x300) static uint32_t* NVIC = (uint32_t*)(BASE_ADDRESS_NVIC+OFFSET_ISER0); static uint32_t* IABR = (uint32_t*)BASE_ADDRESS_IABR; uint32_t reader = 0; void NVIC_Init(){ EnablePrivilegedMode(); *NVIC |= 0x10000000; reader = ((*IABR) & 0x10000000); //Read whether IRQ28's enabled or not if(reader == 0x10000000){ GPIOADriver_Set(PIN5); } }
i figured out how to enter in privileged mode, just doin SVC (supervisor call), after that i try to write NVIC_ISER0 the 28 bit, and READ the IABR so that to know whether the IRQ's active or no, if is, turn on the LED, but it doesn't work yet :(, the LED doesn't turn on. therefore it is not activeted! why?¿ any idea?
You want to set bit 28! Check line 18 carefully.
Ah, and enable all warnings in your compiler. There are some weird things in your code.
Hi, thanks for your replie, i fix that ,*NVIC_ISER0 |= 0x10000000; instead *NVIC_ISER0 |= 0x001C;, and other issues has been fixed too, it doesn't work yet, i should enable privileged mode, really? how can i do this?¿
You cannot "enable" privilege mode by just doing an "svc #0" unless you have some exception handler installed.
Anyway, out of reset you are in privileged mode.
I recommend:
https://www.sciencedirect.com/book/9780124080829/the-definitive-guide-to-arm-cortex-m3-and-cortex-m4-processors
It will answer all you questions and more.
