which is better for performance fetching instructions from flash or SRAM?
If I copy the firmware to SRAM and start execute program from there using STM32F429 (which means that system bus is used to fetch instructions instead of I-code bus).
At this case do fetching instructions and data access can be carried out in parallel ? and which is better for performance fetching instructions from flash or SRAM?
( I know that SRAM is faster than FLASH).
