Hello Guys
I am trying to add an external parallel flash Memory with Cortex-M0. I see that cmsdk_ahb_to_extmem16.v file uses Lower byte enable and upper byte enable pin to select the bytes in the Memory. I was trying to find the commercially available external parallel flash Memory to integrate with the processor. But could not get. Does anyone know about such flash memory?
I am sharing the interfaces of the file. If you notice the output wires you can get it. Please help me find the appropriate memory. The block diagram can be found here.https://developer.arm.com/docs/ddi0479/c/basic-ahb-lite-components/ahb-to-external-sram-interface .// Port Definitions // -------------------------------------------------------------------------- input wire HCLK, // Clock input wire HRESETn, // Reset input wire HSEL, // Device select input wire [AW-1:0] HADDR, // Address input wire [1:0] HTRANS, // Transfer control input wire [2:0] HSIZE, // Transfer size input wire HWRITE, // Write control input wire [31:0] HWDATA, // Write data input wire HREADY, // Transfer phase done output wire HREADYOUT, // Device ready output wire [31:0] HRDATA, // Read data output output wire HRESP, // Device response (always OKAY) // Static configuration input wire [2:0] CFGREADCYCLE, // Read cycles input wire [2:0] CFGWRITECYCLE, // Write cycles input wire [2:0] CFGTURNAROUNDCYCLE, // Turn around cycles input wire CFGSIZE, // port size (0=8-bit, 1=16-bit) input wire [15:0] DATAIN, // Data input output wire [AW-1:0] ADDR, // Address output output wire [15:0] DATAOUT, // Data output output wire DATAOEn, // Tristate buffer output enable output wire WEn, // Write Controls output wire OEn, // Output enable (read) output wire CEn, // Chip enable output wire LBn, // Lower byte enable output wire UBn); // Upper byte enable
